Add 4 RS232 serial ports with 5V or 12V selectable power output to your computer, through a PCI slot. The PCI4S954PW 4-Port PCI Serial Card (with power output) turns a PCI slot into 4 RS232 (DB9) serial connections and enables compatible devices to draw power from the serial ports.
Suitable for many RS232-powered serial applications, this PCI serial card offers a selectable 5V or 12V power option, capable of power output using pin 1, 4, 8 or 9, which enables you to configure the card to suit the requirements of your powered RS232 devices.
A flexible solution for adding serial ports to full-sized, or small form factor systems, the 4-port serial card includes both low and full profile brackets while the included breakout cable helps to avoid cluttered connections.
- StarTech.com 4 Port RS232 PCI Serial Card Adapter with Power Output - serial adapter - PCI - RS-232 x 4
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- PCI Specification Revision
- PCI 3.0
- Ports
- RS-232 x 4
- 1.9 cm x 5.7 cm x 12 cm
- 95 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 460.8 Kbps
- Processor
- OXUPCI954
- System Requirements
- Microsoft Windows Server 2003, Linux 2.4.x, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7, Windows 10 (32/64 bits)
- Limited lifetime warranty
- Serial adapter
- Form Factor
- Plug-in card
- PCI
- PCI 3.0
- Ports
- RS-232 x 4
- Connectivity Technology
- Wired
- RS-232
- 460.8 Kbps
Processor / Memory
- Processor
- OXUPCI954
- 4 x RS-232 - 9 pin D-Sub (DB-9) , 1 - 4 PIN internal power
- Compatible Slots
- 1 x PCI
- Included Accessories
- Low-profile bracket
- OS Required
- 1.9 cm
- 5.7 cm
- 12 cm
- 95 g
- 0 °C
- 50 °C
- 5 - 85% (non-condensing)
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.43 |
StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD | In Stock | £155.21 |
