StarTech.com 4 Port RS232 Mini PCI Express Serial Card with 16650 UART
Quicklinx: 7TGSWS00 Mfr#: MPEX4S552
£31.32 ex VAT
£37.58 inc VAT
Add Four RS232 Serial Ports to an Embedded System through a mini PCI Express Slot.
The MPEX4S952 4-Port RS232 Mini PCI Express Serial Card (16650 UART) turns a mini-PCIe slot into four RS232 (DB9) serial ports with data rates up to 921.6 Kbps - a cost-saving solution for adding serial support to embedded systems missing the functionality.
A native PCIe single-chip design enables you to take advantage of full PCI Express bus capability, by providing improved speed and reliability while reducing the load applied to the CPU by as much as 48% over conventional "bridge chip" serial cards.
StarTech.com 4 Port RS232 Mini PCI Express Serial Card w/ 16650 UART (MPEX4S552) - serial adapter - Mini PCI Express - RS-232 x 4
Serial adapter
Plug-in card
Interface (Bus) Type
Mini PCI Express
PCI Specification Revision
PCIe 1.1
Ports
RS-232 x 4
1 cm x 6 cm x 3 cm
150 g
RS-232
Data Transfer Rate
921.6 Kbps
MosChip Semiconductor MCS9904CV-AA
Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Linux Kernel 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
Serial adapter
Plug-in card
Mini PCI Express
PCIe 1.1
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Processor / Memory
4 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x Mini PCI Express - full-length
FCC, RoHS
1 cm
6 cm
3 cm
150 g
Limited warranty - lifetime
55 °C
5 - 95%
7TGS StarTech.com 24in Internal USB Motherboard Header to 2 Port Serial RS232 Adapter In Stock £46.21
