StarTech.com 4 Port Professional VGA USB KVM Switch with Hub
Quicklinx: 4V28WS00 Mfr#: SV431USB
Type: KVM switch
Ports: 4
Connectivity: KVM
£87.88 ex VAT
£105.45 inc VAT
Control up to 4 PC or Mac computers from a single keyboard, mouse and monitor and share any USB device between all connected computers. The SV431USB 4 Port rack mountable VGA USB KVM Switch with Hub offers simple control of up to four computers from a single monitor/display and USB peripheral set (keyboard, mouse).
The USB KVM switch features an integrated 4 port USB hub, allowing you to share connected USB peripherals between the four controlled PC/Mac computers as though the devices were connected directly.
Offering convenient placement and installation options, the KVM switch features a 1U rack-mountable form factor and rear port connection to master and slave computers, allowing you to make the necessary device connections without disrupting your workspace.
A cross-platform solution, the KVM switch supports high resolution applications at up to 1920x1440 and provides a smooth operating experience when controlling mixed (Windows/Mac OS/Linux) environments.
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub - 1U Rack-mountable KVM Switch (SV431USB) - KVM switch - 4 ports
Enclosure Type
1U
Subtype
KVM
Ports
4 x KVM port(s)
KVM Users Qty
1 local user
22 cm x 13 cm x 4.4 cm
0.9 kg
3-year warranty
P/N: SV431RACK, SVUSB2N1_10, SVUSB2N1_15, SVUSB2N1_6
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
4 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
Status Indicators
Port status, power
4 x USB Type B , 4 x VGA HD-15 , 1 x VGA HD-15 , 2 x USB Type A
Rack Mounting Kit
Optional
22 cm
13 cm
4.4 cm
0.9 kg
Limited warranty - parts and labour - 3 years - carry-in
4V28 StarTech.com 6 ft 2-in-1 USB KVM Cable In Stock £7.06
4V28 StarTech.com 10 ft 2-in-1 Universal USB KVM Cable In Stock £11.01
4V28 StarTech.com 4 Port Black USB KVM Switch Kit with Cables and Audio In Stock £61.85
4V28 StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £87.88
4V28 StarTech.com Spare 5V DC UK Power Adapter for SV231USB & SV431USB In Stock £8.36
4V28 StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £22.32
4V28 StarTech.com 15 ft 2-in-1 Universal USB KVM Cable In Stock £15.07
4V28 StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD In Stock £146.35
Type: KVM switch
Ports: 4
Connectivity: KVM
