StarTech.com 4 Port Professional USB PS/2 KVM Switch
Quicklinx: 3ZNRWS00 Mfr#: SV431HGB
This 4 USB+PS/2 KVM Switch offers a professional-grade computer management tool that allows you to control up to 4 directly connected computers from one source, with support for display resolutions of up to 1920x1440 - a perfect solution for high-resolution applications.
A versatile KVM solution, the switch can be used to control computers that support either USB or PS/2 connections (mouse, keyboard), and offers a scalable method of managing connected systems using cascaded installation (using multiple KVM switches).
Offering broad compatibility, the KVM switch is designed to work with Dell, Compaq, IBM and HP servers and all PC notebook computers, ensuring a smooth and reliable operating experience.
The KVM switch features a durable all-metal body that is suitable for virtually any operating environment including corporate or industrial operating applications.
This professional-grade USB+PS/2 KVM Switch provides reliable computer management.
StarTech.com 4 Port Professional USB PS/2 KVM Switch - KVM switch - 4 ports
Subtype
KVM
Ports
4 x KVM port(s)
KVM Users Qty
1 local user
22 cm x 13 cm x 4.4 cm
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2
Max Resolution
1920 x 1440
4 x VGA HD-15 , 4 x USB Type B , 3 x keyboard (PS/2) / mouse (PS/2) , 1 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2)
External power adapter
3 x keyboard / mouse cable
FCC
22 cm
13 cm
4.4 cm
