StarTech.com 4 Port Portable USB 2.0 Hub
Quicklinx: CMCYWS00 Mfr#: ST4200MINI2
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
Form Factor: External
10 In Stock
£8.59 ex VAT
£10.30 inc VAT
Add four USB 2.0 ports to your computer, using this cost-effective, compact USB hub. Here's a simple and cost-effective way to expand your computer's connectivity by adding extra USB ports. This 4-port USB hub turns a single USB connection into four connections and features a compact, USB-powered design that makes it perfect for travel. The hub also features a small-footprint housing, which means it takes up less desk space.
With its compact and lightweight design, this 4-port USB hub is tailored for mobility. You can easily tuck it into your laptop bag when traveling, which makes it easy to expand your connection options almost anywhere you need to. It's perfect for connecting common USB devices such as a mouse, keyboard, or flash drive, right when you need them.
This versatile hub features a built-in USB cable and is bus-powered, so it draws its power directly from your computer's USB port. This means there are fewer cables to carry with you when you travel because it doesn't need an external power adapter.
With all four USB 2.0 ports on one side, this hub makes it easier to access ports to connect or disconnect devices. Plus, you can easily connect USB devices that have larger connectors or plugs, because the hub offers extra spacing between each USB port.
This universal USB 2.0 hub will work with a wide range of computers, because it requires no additional software or drivers. It installs automatically when you connect it to your laptop or desktop, so you can be up and running quickly. It also works with a range of operating systems such as Windows, Mac, Linux and Chrome OS, so it's multi-platform compatible.
  • Compact design
    The small form factor of the hub makes it easy to carry and store, perfect for users who frequently travel.
  • Robust compatibility
    This hub is compatible with Mac systems, ensuring smooth operation for a variety of USB devices.
  • Plug-and-play functionality
    With easy Plug-and-Play installation, there is no need for special drivers or complicated setups, allowing users to connect devices instantly.
  • Reliable operation
    Designed to function in temperatures ranging from 0°C to 40°C, this hub maintains performance in various environments.
  • Environmentally compliant
    This device adheres to FCC, RoHS, and WEEE standards, ensuring it is safe and eco-conscious for users.
Startech 4 Port USB 2.0 Hub - USB Bus Powered - Portable Multi Port USB 2.0 Splitter and Expander Hub - Small Travel USB Hub (ST4200MINI2) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
USB powered
8.2 cm x 2.4 cm x 1.5 cm
31 g
Black, silver
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 2.0
USB powered
Status Indicators
4 x USB 2.0 Type A , 1 x USB 2.0 Type A
Black, silver
1 x USB power cable - 10 cm
Plug and Play, FCC, RoHS, WEEE
8.2 cm
2.4 cm
1.5 cm
31 g
0 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
CMCY StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £61.41
CMCY StarTech.com 4 Port PCI Express Low Profile High Speed USB Card In Stock £29.08
CMCY StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £85.03
CMCY StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.19
CMCY StarTech.com 1m USB 2.0 A to A Cable - M/M In Stock £5.19
CMCY StarTech.com 2m (6ft) Long Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £14.91
CMCY StarTech.com 4 Port Portable USB 3.0 Hub In Stock £24.39
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
