Add 4 high-speed RS-232 serial ports to your computer with a buffered serial card from StarTech.com. The card uses a 16-Byte buffer in both the receive and transmit channels simultaneously, reducing the number of CPU interrupts and improving system performance. Compatible with both 3.3 and 5 volt motherboards, and uses DB9 connectors for use with a wide range of serial peripherals. Suitable for industrial applications, this card is compatible with a wide range of operating systems, including Windows, DOS, Linux, and Unix.
- StarTech.com 4 Port PCI RS232 Serial Adapter Card High Speed 16950 cable included - serial adapter - PCI - RS-232 x 4
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- Ports
- RS-232 x 4
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- System Requirements
- SCO OpenServer, Microsoft Windows 95/98, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP
- Limited lifetime warranty
- Serial adapter
- Form Factor
- Plug-in card
- PCI
- Ports
- RS-232 x 4
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- 4 x RS-232 - 9 pin D-Sub (DB-9) (on cable)
- Compatible Slots
- 1 x PCI
- Cables Included
- 1 x serial cable (external)
- OS Required
- Limited warranty - lifetime
StarTech.com DB9 to DB25 Serial Adapter - M/F | In Stock | £5.17 |
