Add 4 high-speed RS-232 serial ports to your PC through a PCI Express expansion slot. The PEX4S552 4-port PCI Express-based serial adapter card lets you turn a PCI Express slot into 4 RS-232 (DB9) serial connections.
The adapter card is based on a native single chip design that allows you to harness the full capability of PCI Express (PCIe) - providing optimum reliability and speed while reducing the load applied to the CPU by as much as 48% over conventional serial cards.
The RS-232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista/Windows 7/Server 2008 R2 (32 and 64 bit), Linux Kernel 2.6.11 and up, as well as MAC OS 10.4 and above.
To ensure broad compatibility, the 4 port PCIe Serial Adapter card includes an optional low profile/half-height bracket that allows the card to be installed in virtually any computer case - making it easier to add serial ports to a PCI Express enabled computer, regardless of the size of the computer case.
- StarTech.com 4 Port Dual Profile PCI-Express UART Serial Card - serial adapter - PCIe - RS-232 x 4
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- PCI Specification Revision
- PCIe 1.0a
- Ports
- RS-232 x 4
- 21 cm x 12 cm
- 75 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 460 Kbps
- System Requirements
- Microsoft Windows 2000, Apple MacOS X 10.4 or later, SuSE Linux Kernel 2.6.x, Microsoft Windows 2003, Microsoft Windows Vista / XP
- Limited lifetime warranty
- Serial adapter
- Form Factor
- PCI Express x1
- PCIe 1.0a
- Ports
- RS-232 x 4
- Connectivity Technology
- Wired
- RS-232
- 460 Kbps
- 4 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket, full-height bracket, 1 x bracket with two DB9 connectors
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 21 cm
- 12 cm
- 75 g
- Limited warranty - lifetime
StarTech.com 4 port PCI Express Serial Card
