StarTech.com 4 Port PCI Express RS232 Serial Adapter Card - Low Profile
Quicklinx: FQP2WS00 Mfr#: PEX4S953LP
Wired / Wireless: Wired
Protocol: RS-232
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Serial adapter
£87.84 ex VAT
£105.40 inc VAT
PCI Express to Serial Adapter 921.6Kbps Windows and Linux Compatible. This PCI Express RS232 serial adapter card lets you add four RS232 (DB9) serial ports to your computer through a PCI Express (PCIe) slot. The 4 port PCIe serial card enables you to interact with serial devices, such as card readers, printers, PIN pads, and modems, at speeds of up to 921.6Kbps.
Maximum Compatibility
With broad OS support, including for Windows and Linux, this PCI E serial card is easy to integrate into mixed environments. The card comes pre-configured with low-profile brackets, and includes
optional full-profile brackets, so installation is easy regardless of the case form factor. This card is a direct replacement for PEX4S952LP.
Experience Optimal Technology
This PCIe to serial adapter supports the following features:
Compatible with industry standard 16950 UART
Supports max baud rate of up-to 921.6Kbps
Provides 5/12V power output on Pin 9 when external power is connected
256-byte depth FIFO cache per transmitter and receiver
Supports 9, 8, 7, 6, 5 data bits (one per port)
Asix AX99100 chipset
PCI Express 1.1 compliant
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
PEX4S03LP is backed by a StarTech.com lifetime warranty and free lifetime technical support.
  • Enhanced connectivity
    Equipped with four 9-pin D-Sub (DB-9) RS-232 connectors, this adapter card ensures a wide range of external serial device connections, making it suitable for various professional setups.
  • High-speed data transfer
    With a data transfer rate of up to 921.6 Kbps, the card facilitates rapid information exchange, supporting efficient operations and minimizing wait times for data processing.
  • Broad compatibility
    Designed to work seamlessly across Windows, macOS, and Linux platforms, this adapter card offers a versatile solution for integrating serial devices into almost any computer system.
  • Durable and compliant
    Adhering to FCC, REACH, RoHS, and WEEE standards, this product promises reliability and adherence to environmental and safety regulations, ensuring a responsible choice for your tech needs.
StarTech.com 4-port PCI Express RS232 Serial Adapter Card, PCIe RS232 Serial Host Controller Card, PCIe to Serial DB9, 16950 UART, Low Profile Desktop Expansion Card, Windows, macOS, Linux - Full/Low-Profile (PEX4S953LP) - serial adapter - PCIe - RS-232 x 4
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.1
Ports
RS-232 x 4
6.3 cm
RS-232
Data Transfer Rate
921.6 Kbps
ASIX AX99100
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x - 2.6.x LTS versions only
Serial adapter
PCI Express x1
PCIe 1.1
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Full duplex mode, 256-byte FIFO
Processor / Memory
ASIX AX99100
4 x RS-232 - 9 pin D-Sub (DB-9) (on cable) , 1 x SATA power - 15 pin Serial ATA power (internal)
Full-height bracket
FCC, RoHS, WEEE, REACH
6.3 cm
Shipping Width
21.3 cm
Shipping Depth
14.9 cm
Shipping Height
5.1 cm
Shipping Weight
386 g
Limited warranty - lifetime
-10 °C
80 °C
5 - 85%
FQP2 StarTech.com DB9 RS232 Serial Null Modem Adapter - M/F In Stock £5.24
FQP2 StarTech.com 1m Black DB9 Null Modem Cable In Stock £3.89
FQP2 StarTech.com 2m Black DB9 Null Modem Cable In Stock £4.34
FQP2 StarTech.com 2 Port PCI Express RS232 Serial Adapter Card In Stock £37.07
FQP2 StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD In Stock £159.61
FQP2 StarTech.com PCIe Card with Serial and Parallel Port - PCI Express Combo In Stock £34.94
FQP2 StarTech.com Serial/Parallel PCI Card In Stock £19.05
FQP2 StarTech.com 1-Prt PCI Express Serial Card In Stock £38.02
FQP2 StarTech.com PCIe Dual Serial Port Card In Stock £45.05
Protocol: RS-232
