The PEXUSB4DP is a low profile 4 port USB card designed for versatility and performance.
Providing simple system expansion for added peripheral connections, this PCI Express USB card adds 3 external USB 2.0 slots and 1 internal USB 2.0 slot, with support for high speed USB 2.0 data transfer rates of up to 480 Mbps, and includes WHQL certified drivers and easy plug and play installation.
Capable of adapting to virtually any PC case form factor, the low profile USB card includes a standard profile bracket for installation in full form factor cases.
- StarTech.com 4 Port PCI Express Low Profile High Speed USB Card - PCIe USB 2.0 Card - PCI-E USB 2.0 Card (PEXUSB4DP) - USB adapter - PCIe - 4 ports
- USB adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- PCI Specification Revision
- PCIe 1.1
- 9 cm x 2 cm x 8 cm
- 46 g
- Ports Qty
- 4 ports
- Data Link Protocol
- USB, USB 2.0
- Data Transfer Rate
- 480 Mbps
- USB 1.1, USB 2.0
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.6 - 10.10, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux 3.5.x - 4.11.x LTS versions only
- 2-year warranty
- Designed For
- P/N: ST4200MINI2
- USB adapter - 4 ports
- Form Factor
- PCI Express x1
- PCIe 1.1
- Connectivity Technology
- Wired
- USB, USB 2.0
- 480 Mbps
- USB 1.1, USB 2.0
- 3 x USB 2.0 - 4 pin USB Type A (external) , 1 x USB 2.0 - 4 pin USB Type A (internal)
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket, full-height bracket
- WHQL, FCC, RoHS
- OS Required
- 9 cm
- 2 cm
- 8 cm
- 46 g
- Limited warranty - 2 years
- 0 °C
- 75 °C
- Designed For
- P/N: ST4200MINI2
