StarTech.com 4 Port PCI Express Low Profile High Speed USB Card
Quicklinx: 6BDQWS00 Mfr#: PEXUSB4DP
Type: USB adapter
Compatibility: PC
Interface: PCI Express x1
Hurry, only 2 left in stock!
£29.08 ex VAT
£34.89 inc VAT
The PEXUSB4DP is a low profile 4 port USB card designed for versatility and performance.
Providing simple system expansion for added peripheral connections, this PCI Express USB card adds 3 external USB 2.0 slots and 1 internal USB 2.0 slot, with support for high speed USB 2.0 data transfer rates of up to 480 Mbps, and includes WHQL certified drivers and easy plug and play installation.
Capable of adapting to virtually any PC case form factor, the low profile USB card includes a standard profile bracket for installation in full form factor cases.
StarTech.com 4 Port PCI Express Low Profile High Speed USB Card - PCIe USB 2.0 Card - PCI-E USB 2.0 Card (PEXUSB4DP) - USB adapter - PCIe - 4 ports
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.1
9 cm x 2 cm x 8 cm
46 g
Ports Qty
4 ports
USB, USB 2.0
Data Transfer Rate
480 Mbps
USB 1.1, USB 2.0
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.6 - 10.10, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux 3.5.x - 4.11.x LTS versions only
P/N: ST4200MINI2
USB adapter - 4 ports
PCI Express x1
PCIe 1.1
Wired
USB, USB 2.0
Data Transfer Rate
480 Mbps
USB 1.1, USB 2.0
3 x USB 2.0 - 4 pin USB Type A (external) , 1 x USB 2.0 - 4 pin USB Type A (internal)
Compatible Slots
1 x PCI Express x1
Low-profile bracket, full-height bracket
WHQL, FCC, RoHS
9 cm
2 cm
8 cm
46 g
75 °C
P/N: ST4200MINI2
6BDQ StarTech.com 4 Port PCI Express Low Profile High Speed USB Card In Stock £29.08
6BDQ StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.76
Type: USB adapter
Compatibility: PC
