StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering
Quicklinx: 8M4DWS00 Mfr#: PEXSAT34RH
Compatibility: PC, Mac
  • Windows 8 (32/64 bits)
£57.58 ex VAT
£69.09 inc VAT
Add 4 Internal SATA III (6Gbps) ports to a computer through a PCI Express x2 slot. The PEXSAT34RH 4-Port PCI Express 2.0 SATA Controller Card with HyperDuo adds 4 AHCI SATA III ports to a computer through a PCIe slot (x2), delivering multiple internal 6Gbps connections for high-performance hard drives and Solid State Drives (SSDs).
Featuring HyperDuo technology, the SATA card offers SSD auto-tiering which lets you balance the performance advantages of SSD storage with the cost-effectiveness and large capacity of standard hard drives. By combining SSD and HDD drives into a single volume (up to 3 SSD + 1 HDD), HyperDuo discreetly works in the background to identify and move frequently accessed files to the faster SSD drive(s) for improved data throughput - up to 80% of SSD performance! (Note: The HyperDuo automatic storage tiering feature is compatible with computers that use a BIOS.)
The PCIe SATA controller card supports Port Multiplier (PM), enabling multiple SATA drives to be connected to one port over a single cable, for a total of 7 drives (Up to 4 drives through PM on one port, and a single drive to the remaining 3 ports). Plus, the SATA controller card offers an effective hardware RAID solution, with native RAID (0, 1, 1+0) support.
StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering - PCIe SATA 3 Controller Adapter (PEXSAT34RH) - storage controller (RAID) - SATA 6Gb/s - PCIe 2.0 x2
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe 2.0 x2
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Disk array (RAID)
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10, JBOD
Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 10 (32/64 bits)
12 cm x 7 cm x 2 cm
49 g
P/N: ST521PMINT
Host Bus
PCIe 2.0 x2
Storage Controller
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Disk array (RAID)
Channel Qty
4
RAID Level
Marvell 88SE9230
4 x SATA 6Gb/s - SATA (internal)
Low-profile bracket
FCC, RoHS
12 cm
7 cm
2 cm
49 g
5 °C
50 °C
20 - 80% (non-condensing)
P/N: ST521PMINT
8M4D StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
8M4D StarTech.com 12in Latching SATA Cable In Stock £3.34
8M4D StarTech.com 18in Latching SATA Cable In Stock £3.74
8M4D StarTech.com 2 Port SATA 6 Gbps PCI Express SATA Controller Card In Stock £27.79
8M4D StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering In Stock £57.58
Compatibility: PC
Compatibility: Mac
Stock Status: In stock
