StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering
Quicklinx: 8M4DWS00 Mfr#: PEXSAT34RH
Type: Storage Controller
Compatibility: PC, Mac
Interface: PCI Express 2.0
  • Windows 8 (32/64 bits)
Hurry, only 3 left in stock!
£64.73 ex VAT
£77.67 inc VAT
Add 4 Internal SATA III (6Gbps) ports to a computer through a PCI Express x2 slot. The PEXSAT34RH 4-Port PCI Express 2.0 SATA Controller Card with HyperDuo adds 4 AHCI SATA III ports to a computer through a PCIe slot (x2), delivering multiple internal 6Gbps connections for high-performance hard drives and Solid State Drives (SSDs).
Featuring HyperDuo technology, the SATA card offers SSD auto-tiering which lets you balance the performance advantages of SSD storage with the cost-effectiveness and large capacity of standard hard drives. By combining SSD and HDD drives into a single volume (up to 3 SSD + 1 HDD), HyperDuo discreetly works in the background to identify and move frequently accessed files to the faster SSD drive(s) for improved data throughput - up to 80% of SSD performance! (Note: The HyperDuo automatic storage tiering feature is compatible with computers that use a BIOS.)
The PCIe SATA controller card supports Port Multiplier (PM), enabling multiple SATA drives to be connected to one port over a single cable, for a total of 7 drives (Up to 4 drives through PM on one port, and a single drive to the remaining 3 ports). Plus, the SATA controller card offers an effective hardware RAID solution, with native RAID (0, 1, 1+0) support.
  • Versatile RAID support
    This controller card supports various RAID levels including RAID 0 for performance, RAID 1 for data redundancy, RAID 10 for a combination of both, and JBOD for flexible storage management.
  • High-speed data transfer
    With a data transfer rate of 6 Gbit/s, this card allows for rapid data movement, optimizing overall system performance during heavy workloads.
  • Compact and efficient design
    The low-profile form factor enables easy installation in space-constrained environments without sacrificing performance, providing a fit for compact systems.
  • Broad compatibility
    Tailored for Mac systems, this storage controller ensures seamless integration, allowing users to expand their storage without complications.
  • Reliable standards compliance
    Meets FCC and RoHS standards, assuring users of environmental and safety while delivering consistent performance.
StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering - PCIe SATA 3 Controller Adapter (PEXSAT34RH) - storage controller (RAID) - SATA 6Gb/s - PCIe 2.0 x2
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe 2.0 x2
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10, JBOD
Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 10 (32/64 bits)
12 cm x 7 cm x 2 cm
49 g
P/N: ST521PMINT
Host Bus
PCIe 2.0 x2
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
Channel Qty
4
RAID Level
Marvell 88SE9230
4 x SATA 6Gb/s - SATA (internal)
Low-profile bracket
FCC, RoHS
12 cm
7 cm
2 cm
49 g
5 °C
50 °C
20 - 80% (non-condensing)
P/N: ST521PMINT
8M4D StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
8M4D StarTech.com 12in Latching SATA Cable In Stock £5.48
8M4D StarTech.com 18in Latching SATA Cable In Stock £3.89
8M4D StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering In Stock £64.73
8M4D StarTech.com 2x M.2 SSD Controller - PCIe In Stock £21.26
8M4D StarTech.com 3PT M.2 SSD Card - PCIe 3.0 In Stock £28.29
Compatibility: PC
Compatibility: Mac
