Add 4 FireWire ports to a desktop computer through a PCI slot. This 4 Port (3 External/1 Internal) PCI 1394 FireWire Adapter Card lets you connect iPods, MP3 players, portable drives, digital camcorders and more to your desktop computer.
The FireWire adapter card supports hot-swapping, so you'll be able to plug, unplug, and swap your FireWire peripherals with ease.
Plus, the adapter provides both standard profile and low profile/half-height brackets for adapting to slimline or small form factor system applications.
If you require digital video editing software, StarTech.com offers a complete FireWire kit with our PCI1394 4 card. This software is compatible with Windows operating systems only.
Versatile connectivity options
With three external ports and one internal port, this adapter card enables users to connect multiple FireWire devices at once, enhancing usability and efficiency. -
Fast data transfer rates
The card supports a data transfer rate of 400 Mbps, ensuring quick and efficient handling of data between connected devices. -
Easy installation
Designed as a plug-in card with a PCI interface, installation is straightforward, making it quick to add additional FireWire ports to your laptop. -
Broad compatibility
This FireWire adapter is compatible with Mac systems, ensuring that users can integrate it into their existing hardware setup. -
Reliable wired connections
The wired connectivity technology offers stable and consistent performance, reducing the risk of data loss or connection drops during use.
- StarTech.com 4 port PCI 1394a FireWire Adapter Card - 3 External 1 Internal FireWire PCI Card for Laptops (PCI1394MP) - FireWire adapter - PCI - 3 ports
- FireWire adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- Ports Qty
- 3 ports
- Data Link Protocol
- Firewire
- Data Transfer Rate
- 400 Mbps
- System Requirements
- Microsoft Windows 2000, Apple MacOS 8.6 or later, Microsoft Windows 98/ME, Microsoft Windows XP, Windows 10 (32/64 bits)
- Limited lifetime warranty
- FireWire adapter - 3 ports
- Form Factor
- Plug-in card
- PCI
- Connectivity Technology
- Wired
- IEEE 1394 (FireWire)
- 400 Mbps
- 3 x FireWire - 6 PIN FireWire - male - 3 (external) , 1 x FireWire - 6 PIN FireWire - male - 1 (internal)
- Compatible Slots
- 1 x PCI
- OS Required
- Limited warranty - parts and labour - lifetime - carry-in
