StarTech.com 4 port PCI 1394a FireWire Adapter Card - 3 External 1 Internal
Quicklinx: 3ZQWWS00 Mfr#: PCI1394MP
Type: FireWire adapter
Compatibility: PC, Mac
Interface: PCI
£19.64 ex VAT
£23.56 inc VAT
Add 4 FireWire ports to a desktop computer through a PCI slot. This 4 Port (3 External/1 Internal) PCI 1394 FireWire Adapter Card lets you connect iPods, MP3 players, portable drives, digital camcorders and more to your desktop computer.
The FireWire adapter card supports hot-swapping, so you'll be able to plug, unplug, and swap your FireWire peripherals with ease.
Plus, the adapter provides both standard profile and low profile/half-height brackets for adapting to slimline or small form factor system applications.
If you require digital video editing software, StarTech.com offers a complete FireWire kit with our PCI1394 4 card. This software is compatible with Windows operating systems only.
  • Versatile connectivity options
    With three external ports and one internal port, this adapter card enables users to connect multiple FireWire devices at once, enhancing usability and efficiency.
  • Fast data transfer rates
    The card supports a data transfer rate of 400 Mbps, ensuring quick and efficient handling of data between connected devices.
  • Easy installation
    Designed as a plug-in card with a PCI interface, installation is straightforward, making it quick to add additional FireWire ports to your laptop.
  • Broad compatibility
    This FireWire adapter is compatible with Mac systems, ensuring that users can integrate it into their existing hardware setup.
  • Reliable wired connections
    The wired connectivity technology offers stable and consistent performance, reducing the risk of data loss or connection drops during use.
StarTech.com 4 port PCI 1394a FireWire Adapter Card - 3 External 1 Internal FireWire PCI Card for Laptops (PCI1394MP) - FireWire adapter - PCI - 3 ports
FireWire adapter
Plug-in card
Interface (Bus) Type
PCI
Ports Qty
3 ports
Firewire
Data Transfer Rate
400 Mbps
Microsoft Windows 2000, Apple MacOS 8.6 or later, Microsoft Windows 98/ME, Microsoft Windows XP, Windows 10 (32/64 bits)
FireWire adapter - 3 ports
Plug-in card
PCI
Wired
IEEE 1394 (FireWire)
Data Transfer Rate
400 Mbps
3 x FireWire - 6 PIN FireWire - male - 3 (external) , 1 x FireWire - 6 PIN FireWire - male - 1 (internal)
Compatible Slots
1 x PCI
Limited warranty - parts and labour - lifetime - carry-in
3ZQW StarTech.com 4 port PCI 1394a FireWire Adapter Card - 3 External 1 Internal In Stock £19.64
3ZQW StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter In Stock £47.64
Compatibility: PC
Compatibility: Mac
Interface: PCI
