StarTech.com 4 port Open SFP+ 10G NIC w/ Chassis
Quicklinx: DXG7WS00 Mfr#: BNDTB410GSFP
This Thunderbolt 3 network adapter connects your Thunderbolt 3 enabled device to a 10GbE network via a PCIe expansion chassis. This Thunderbolt 3 10GbE NIC adapter lets you connect a Thunderbolt 3 device to a 10GbE network. The adapter combines the Thunderbolt 3 technology of TB31PCIEX16 with the 10GbE dual-fiber connection of PEX10GSFP4I (Intel XL710 chipset). The assembled adapter features one DisplayPort output, one additional Thunderbolt 3 port, and four open 10GbE SFP+ slots.
The Thunderbolt 3 10GbE NIC adapter is the perfect solution for your mission-critical operations. The network adapter supports 802.1Q VLAN tagging for better network management, 802.3ad link aggregation for greater network speeds, redundancy support for network reliability, and four 10G fiber connections through open SFP+ fiber slots, to build a custom setup.
Requiring only a Phillips type screwdriver and your choice of SFP, this Thunderbolt 3 10GbE NIC adapter can be assembled and connected in minutes.
The Thunderbolt 3 chassis not only pairs well with the 10G fiber network card, the card can be swapped for any PCIe card to help support other functionality and performance. With the extra TB3 port and DP output built into the chassis, you will always have the ability to hook up extended displays to multitask effortlessly.
StarTech.com Thunderbolt 3 to 10GbE Fiber Network Chassis 4 Port - network adapter - PCIe 3.0 x8 - 10 Gigabit SFP+ x 4
Network adapter
Plug-in card
Bundled with
Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) with DisplayPort
Interface (Bus) Type
PCI Express 3.0 x8
PCI Specification Revision
PCIe 3.0
Ports
10 Gigabit SFP+ x 4
Cabling Type
Ethernet 10GBase-LR, Ethernet 10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
Jumbo frame size: 9000
Intel XL710
IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3q
Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x (64-bit) LTS versions
Network adapter
Plug-in card
Bundled with
PCI Express 3.0 x8
PCIe 3.0
Ports
10 Gigabit SFP+ x 4
Wired
Cabling Type
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Status Indicators
Link/activity
Flow control, full duplex capability, Jumbo Frames support, Link Aggregation, VLAN Tagging
Processor / Memory
Intel XL710
4 x 10GBase-SR/LR - SFP+ - female
1 x Thunderbolt 3 / USB-C cable (external) - 50 cm
FCC, RoHS, WEEE
5 °C
20 - 80%
DXG7 StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter In Stock £49.12
DXG7 StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length In Stock £327.11
DXG7 StarTech.com PCI Express X1 to X16 Low Profile Slot Extension Adapter In Stock £19.72
DXG7 StarTech.com PCI Express to 4 Slot PCI Expansion System In Stock £376.57
DXG7 StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.48
DXG7 StarTech.com 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 In Stock £110.54
DXG7 StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels In Stock £46.45
DXG7 StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £80.54
DXG7 StarTech.com USB-C to VGA Adapter In Stock £22.16
DXG7 StarTech.com 4-Port Gigabit NIC - PCIe In Stock £151.83
DXG7 StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £295.64
DXG7 StarTech.com 2x M.2 SSD Controller - PCIe In Stock £21.26
DXG7 StarTech.com USB-C to HDMI Adapter In Stock £15.52
DXG7 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.76
DXG7 StarTech.com USB-C to DisplayPort Adapter In Stock £22.59
DXG7 StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £24.76
