StarTech.com 4 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART
Quicklinx: 7P13WS00 Mfr#: PEX4S553
Type: Serial adapter
Compatibility: PC
Interface: PCI Express 1.1 x1
  • Windows 8 (32/64 bits)
Hurry, only 1 left in stock!
£72.47 ex VAT
£86.96 inc VAT
The PEX4S553 4-Port Native PCI Express RS232 Serial Adapter Card with 16550 UART lets you add 4 RS232 (DB9) serial ports, using a single PCI Express expansion slot.
Based on a native single-chip design, this 4-port serial adapter card allows you to harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge-chip serial cards.
The RS232 Serial Adapter Card includes 4 half-height/low-profile brackets, allowing the card to be installed into almost any PC case, regardless of form factor.
StarTech.com 4 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART - Low Profile Serial Card (PEX4S553) - serial adapter - PCIe 1.1 - 4 ports
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express 1.1 x1
1.9 cm x 13 cm x 12 cm
80 g
Ports Qty
4 ports
RS-232
Data Transfer Rate
128 Kbps
1 x MosChip Semiconductor MCS9904CV-AA
Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Serial adapter - 4 ports
Plug-in card
PCI Express 1.1 x1
Wired
RS-232
Data Transfer Rate
128 Kbps
Processor / Memory
2 x RS-232 - 9 pin D-Sub (DB-9) , 2 x RS-232 - 9 pin D-Sub (DB-9) (on bracket)
Compatible Slots
1 x PCI Express 1.1 x1
4 x low-profile bracket
FCC, RoHS
1.9 cm
13 cm
12 cm
80 g
Limited warranty - lifetime
50 °C
5 - 85%
7P13 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
7P13 StarTech.com 2 Port PCI Express RS232 Serial Adapter Card In Stock £36.05
7P13 StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD In Stock £155.21
7P13 StarTech.com 1-Prt PCI Express Serial Card In Stock £36.98
7P13 StarTech.com PCIe Dual Serial Port Card In Stock £40.31
7P13 StarTech.com PCIe Dual Serial Port Card In Stock £42.80
Compatibility: PC
