StarTech.com 4-Port M.2 to SATA Adapter
Quicklinx: HVM4WS00 Mfr#: 4P-SATA-M2-ADAPTER
Hurry, only 3 left in stock!
£27.72 ex VAT
£33.26 inc VAT
The StarTech.com 4-Port M.2 to SATA Adapter Card is a powerful and versatile solution for expanding your computer's storage capabilities. With the ability to connect up to four hard drives or solid-state drives, this adapter card leverages the ASM1064 Chipset to ensure reliable and efficient data transfer rates of up to 6 Gb/s. It supports both M.2 PCIe 3.0 and SATA 6 Gb/s interfaces, making it a flexible option for a wide range of storage configurations.
Designed for durability, it boasts an impressive mean time between failures (MTBF) of 68,555,579 hours. The card is also equipped with features like S.M.A.R.T. and TRIM support, enhancing the performance and longevity of connected drives. Its compatibility with various operating systems, including Windows, macOS, and Linux, ensures it can be integrated into nearly any system setup. Additional user-friendly features such as a built-in LED indicator, hot-swappable drive support, and compliance with RoHS standards make this adapter card an excellent choice for both novice and experienced users looking to expand their storage options.
  • Efficient expansion
    The 4-Port M.2 to SATA Adapter Card offers a seamless solution for expanding your computer's storage capacity by connecting up to four HDDs or SSDs. Its compatibility with M.2 PCIe 3.0 and SATA 6 Gb/s interfaces ensures a smooth and efficient data transfer experience.
  • High reliability
    Designed with an ASM1064 Chipset and boasting an impressive MTBF of 68,555,579 hours, this adapter card is built for long-term reliability and performance. It supports S.M.A.R.T. and TRIM commands to optimize drive health and efficiency.
  • Versatile compatibility
    This adapter card is compatible with a wide range of operating systems, including Windows, macOS, and Linux, ensuring broad usability across different platforms. Its support for hot-swappable drives and port multipliers enhances its flexibility for various storage configurations.
  • User-friendly features
    With features like a built-in LED indicator for operational status and bus-powered design, this adapter card offers convenience and ease of use. It's also compliant with RoHS standards, making it an environmentally responsible choice.
StarTech.com 4-Port M.2 to SATA Adapter Card, M.2 PCIe 3.0 to SATA HDD/SSD Expansion Card, ASM1064 Chipset, M.2 NVMe to 4x HDD/SSD for Windows/macOS/Linux - interface adapter - SATA - M.2 Card
Interface adapter - internal
Bus Type
M.2 Card
Green
Expansion Bays
1 x internal - M.2 2280
SATA
Data Transfer Rate
6 GBps
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
4
Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Sonoma, Apple macOS Ventura 13.0, Linux 4.15..x or later LTS versions only, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Ubuntu
2.2 cm x 8 cm x 1.1 cm
8 g
Host Bus
M.2 Card
Green
Storage Controller
SATA
Data Transfer Rate
6 GBps
Supported Devices
4
Bays
4 x SATA 6Gb/s - SATA (internal)
1 x M.2 Card - M.2 M+B Key
4 x Serial ATA cable - 50 cm
S.M.A.R.T. support, TRIM support, bus powered, hot-swappable, LED indicator, support port multiplier
MTBF
68,555,579 hours
RoHS
2.2 cm
8 cm
1.1 cm
8 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
142 g
70 °C
20 - 80% RH
HVM4 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.33
HVM4 StarTech.com Tool-Less 2B Mounting Bracket In Stock £6.49
HVM4 StarTech.com 2.5" SSD/HDD Mounting Bracket In Stock £4.13
Type: Interface adapter
