StarTech.com 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART
Quicklinx: 6PGFWS00 Mfr#: PEX4S952LP
Add 4 high-speed RS-232 serial ports to your PC through a low profile PCI Express expansion slot. The PEX4S952LP 4 Port Low Profile Native RS232 PCI Express Serial Card (16950 UART) turns a PCI Express slot into four RS232 (DB9) serial connections.
The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista, Linux Kernel 2.6.11 and up, and ships with a half-height/low profile bracket installed, but also includes an optional full profile bracket that lets you add four serial ports to virtually any computer (regardless of the case form factor).
StarTech.com Replaced by PEX4S953LP - 4 Port Low Profile Native RS232 PCI Express Serial Card (PEX4S952LP) - serial adapter - PCIe - RS-232 x 4
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Ports
RS-232 x 4
2 cm x 9 cm x 8 cm
58 g
RS-232
Data Transfer Rate
460.8 Kbps
1 x Oxford Semiconductor OXPCIe954
Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Vista / 2000 / XP
Serial adapter
PCI Express x1
PCIe 1.0a
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
460.8 Kbps
Software flow control
Processor / Memory
4 x RS-232 - 9 pin D-Sub (DB-9) (on cable)
Compatible Slots
1 x PCI Express x1
WHQL, FCC, RoHS
Software Included
Drivers & Utilities
2 cm
9 cm
8 cm
58 g
Limited warranty - lifetime
-20 °C
85 °C
5 - 85%
6PGF StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.40
