This Keyboard and Mouse (KM) Switch enables switching a single keyboard and mouse between multiple computers using mouse roaming, allowing users to seamlessly move the cursor across multiple screens (i.e., one monitor per computer).
Mouse Roaming
Switch between computers by moving the mouse between monitors, without the need for hotkeys or physical buttons, enabling uninterrupted workflow and increased efficiency. Hotkey and push-button switching are universally compatible. Mouse Roaming is supported by most major desktop operating systems, including Windows, macOS, and Linux. -
Preset Monitor Layouts
To accommodate various physical monitor setups, there are six preset display configurations available. This allows for smooth mouse movement across host monitors. -
Thoughtful Design
Hotkeys enable listening to audio from one computer while controlling another. USB audio and 3.5mm pass-through are available, and LEDs provide visual port selection status, while an audible buzzer confirms hotkey selection. Note: On computers with multiple monitors connected, mouse/keyboard operation is limited to the primary display
- StarTech.com 4-Port KM Switch with Mouse Roaming, USB Switch for Keyboard/Mouse, 3.5mm and USB Audio, Peripheral Sharing for 4 Computers, USB 3.0 Switcher, TAA Compliant - Hotkey/Pushbutton Switching (P4A20132-KM-SWITCH) - keyboard/mouse switch - 2 ports - TAA Compliant
- Keyboard/mouse switch - 2 ports
- Subtype
- USB
- KVM Users Qty
- 1 local user
- Steel housing, mouse roaming
- Power
- AC 100-240 V
- 13 cm x 22 cm x 3.4 cm
- 800 g
- Black
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- USB
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Status Indicators
- Status
- 4 x USB 3.2 Gen 1 Type B host , 4 x headphones mini-jack host , 2 x USB 3.2 Gen 1 Type A console , 3 x USB 2.0 Type A console , 1 x headphones mini-jack console , 1 x headphones mini-jack female , 1 x microphone mini-jack female
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 5 A
- Voltage Required
- AC 100-240 V
- 0.1 Watt
- Black
- MTBF
- 156,000 hours
- RoHS
- TAA Compliant
- 13 cm
- 22 cm
- 3.4 cm
- 800 g
- Shipping Width
- 29.5 cm
- Shipping Depth
- 24.5 cm
- Shipping Height
- 6.3 cm
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 60 °C
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.92 |
StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £11.20 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £7.41 |
StarTech.com 2m 6ft USB 3.0 C to B Cable | In Stock | £12.71 |
