This 4 Port Dual Link DVI USB KVM Switch provides simple, yet comprehensive control of up to four directly connected computers as well as audio switching capability and support for high resolution applications (supports 1080p, and up to 2560x1600 @ 60Hz, up to 3840 x 2400 at lower refresh rates, and Apple Cinema quality resolutions) - a superior switching solution that integrates perfectly into multimedia environments.
The DVI USB KVM Switch is compatible with all USB supported operating systems, and features a built-in USB 2.0 hub that allows you to share up to three high speed USB devices between computers.
- StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio and USB 2.0 Hub (SV431DVIUAHR) - KVM / audio / USB switch - 4 ports
- KVM / audio / USB switch - 4 ports - cascadable
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- 22 cm x 13 cm x 4.4 cm
- 1.8 kg
- Black
- 3-year warranty
- Designed For
- P/N: DVID4N1USB10, DVID4N1USB15, DVID4N1USB6, SV431RACK, SVA5N3NEUA, USBDVI4N1A10, USBDVI4N1A6
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2560 x 1600 @ 60 Hz
- Built-in Devices
- USB Hub
- Status Indicators
- Port status
- 4 x USB 2.0 Type B , 4 x DVI-I (dual link) , 4 x audio output mini-jack , 4 x microphone input mini-jack , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x DVI-I (dual link) , 2 x USB 2.0 Type A , 1 x audio output mini-jack , 1 x microphone input mini-jack
- Power Device
- External power adapter
- Black
- Rack Mounting Kit
- Optional
- FCC, RoHS
- 22 cm
- 13 cm
- 4.4 cm
- 1.8 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- Designed For
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub | In Stock | £94.41 |
StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone | In Stock | £10.71 |
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £269.04 |
StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £197.20 |
StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio | In Stock | £192.19 |
StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) | In Stock | £25.12 |
StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio | In Stock | £308.73 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.75 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.05 |
