StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio
Quicklinx: 7P39WS00 Mfr#: SV431DVIUAHR
Type: KVM / audio / USB switch
Ports: 4
Connectivity: KVM
£281.49 ex VAT
£337.78 inc VAT
This 4 Port Dual Link DVI USB KVM Switch provides simple, yet comprehensive control of up to four directly connected computers as well as audio switching capability and support for high resolution applications (supports 1080p, and up to 2560x1600 @ 60Hz, up to 3840 x 2400 at lower refresh rates, and Apple Cinema quality resolutions) - a superior switching solution that integrates perfectly into multimedia environments.
The DVI USB KVM Switch is compatible with all USB supported operating systems, and features a built-in USB 2.0 hub that allows you to share up to three high speed USB devices between computers.
StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio and USB 2.0 Hub (SV431DVIUAHR) - KVM / audio / USB switch - 4 ports
KVM / audio / USB switch - 4 ports - cascadable
Enclosure Type
1U
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
22 cm x 13 cm x 4.4 cm
1.8 kg
3-year warranty
P/N: DVID4N1USB10, DVID4N1USB15, DVID4N1USB6, SV431RACK, SVA5N3NEUA, USBDVI4N1A10, USBDVI4N1A6
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2560 x 1600 @ 60 Hz
Built-in Devices
USB Hub
Status Indicators
Port status
4 x USB 2.0 Type B , 4 x DVI-I (dual link) , 4 x audio output mini-jack , 4 x microphone input mini-jack , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x DVI-I (dual link) , 2 x USB 2.0 Type A , 1 x audio output mini-jack , 1 x microphone input mini-jack
External power adapter
Rack Mounting Kit
Optional
FCC, RoHS
22 cm
13 cm
4.4 cm
1.8 kg
Limited warranty - 3 years
7P39 StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £83.88
7P39 StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £7.64
7P39 StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £239.06
7P39 StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £249.28
7P39 StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £115.65
7P39 StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £131.32
7P39 StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £194.24
7P39 StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £22.32
7P39 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
7P39 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.31
Ports: 4
Connectivity: KVM
