This 4-input HDMI video switch lets you share an HDMI 2.0 display or projector with three HDMI video sources and one DisplayPort video source.
The multi-port HDMI switch lets you deliver the capabilities of your HDMI 2.0 video sources to your UHD 4K60 display. Unlike many 4K switches that only support a 30Hz refresh rate, this switcher box works with HDMI 2.0 displays with output resolutions of up to 4096 x 2160 at 60Hz.
With full support for HDMI 2.0 devices and 4:4:4 chroma subsampling, this 4K HDMI video switcher supports a bandwidth up to 18Gbps. As well, the switch supports DisplayPort 1.2 with HBR2, making it ideal for high-resolution computer tasks.
This multi-port video switcher offers four input options, including one DisplayPort and three HDMI ports, enabling you to switch from one of four sources to your HDMI video display. The mix-and-match input options provide users with a flexible solution so they are not limited to one specific input.
This HDMI switcher box ensures effortless operation with automatic switching that detects and selects a newly connected device. It's perfect for automatically switching to a 4K media player such as a 4K UHD Blu-ray player as soon as it's switched on.
This automatic HDMI switch also supports manual operation, using the included IR remote control or the built-in front-panel toggle switch.
Versatile connectivity
This HDMI video switch features three HDMI ports and one DisplayPort, allowing for multiple source devices to connect and switch easily. -
High-resolution support
The switch supports 4K resolution at 60Hz, ensuring a sharp and clear display for HD visuals across all connected devices. -
Robust audio capabilities
With 7.1 channel audio support, the device enables a rich audio experience, perfect for movies or games. -
Stable operational range
Operating temperatures between 0°C to 45°C with safe storage from -20°C to 70°C make this switch suitable for various environments. -
Regulatory compliance
The device meets key compliance standards such as FCC, RoHS, WEEE, and RCM, ensuring it adheres to safety and environmental guidelines.
- StarTech.com 4 Port HDMI Video Switch - 3x HDMI & 1x DisplayPort - 4K 60Hz - video/audio switch - 4 ports
- Video/audio switch - 4 ports
- Subtype
- HDMI / DisplayPort
- Ports
- 3 x HDMI + 1 x DisplayPort
- 4K resolution support, 7.1 channel audio support
- Power
- AC 120/230 V
- 6.6 cm x 10 cm x 2 cm
- 300 g
- Localisation
- Australia, North America, United Kingdom, Europe
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- Ports
- Status Indicators
- Port status, power
- 3 x HDMI input , 1 x DisplayPort input , 1 x audio input , 1 x HDMI output
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Included Accessories
- Remote control, 4 rubber feet, IR receiver, 2 mounting brackets, 2 screws
- FCC, RoHS, WEEE, RCM
- Localisation
- 6.6 cm
- 10 cm
- 2 cm
- 300 g
- Shipping Width
- 16 cm
- Shipping Depth
- 12.5 cm
- Shipping Height
- 6.5 cm
- Shipping Weight
- 400 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 90%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £12.23 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.37 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £19.66 |
