StarTech.com 4-Port HDMI Splitter, 4K 60Hz
Quicklinx: GXJQWS00 Mfr#: HDMI-SPLITTER-44K60S
Type: Video/audio splitter
Connectivity: HDMI
Ports: 4
£113.00 ex VAT
£135.60 inc VAT
  • 4K 60Hz Resolution
    This 4-way HDMI splitter supports up to 4K 60Hz resolution, at 4:4:4 chroma subsampling. The built-in scaler enables enables the concurrent output of 2 resolutions, ideal for environments where there is a variety of displays, monitors, and projectors.
  • Flexible Audio
    This 4K HDMI Splitter features HDMI, 3.5mm, and Optical audio outputs, enabling connections to a variety of speakers and/or amplifiers. Simultaneous audio output is supported across all the audio ports.
  • Robust Installation Options
    This HDMI splitter supports active HDMI cables and HDMI extenders (sold separately), facilitating installations at a distance from the displays (e.g., within a remote AV component cabinet). The metal enclosure and 8kV air and 4kV contact Electro-static Discharge (ESD) protection is suitable for installation in a variety of environments. This product is backed for 2-years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 4-Port HDMI Splitter, 4K 60Hz HDMI 2.0 Video, 1 In 4 Out HDMI Splitter, 4K HDMI Splitter w/Built-in Scaler, 3.5mm/Optical Audio Port, Durable Metal Housing, HDR/HDCP - 1x4 HDMI Display/Output Splitter (HDMI-SPLITTER-44K60S) - video/audio splitter - 4 ports
Video/audio splitter - 4 ports
Subtype
HDMI
Ports
4 x HDMI
7.1 channel audio support, EDID Management, auto scaler, HDR support, 4K UHD video streaming, 4:4:4 chroma subsampling support, 18 Gbps bandwidth
HDCP 1.4, HDCP 2.2
AC 100-240 V 0.35 A
18 cm x 6.2 cm x 1.4 cm
244 g
Australia, New Zealand, North America, United Kingdom, Europe
Enclosure Type
Desktop
Subtype
HDMI
Ports
4 x HDMI
Max Resolution
3840 x 2160 @ 60 Hz
HDCP 1.4, HDCP 2.2
Status Indicators
Power, HDMI input, HDMI output
1 x HDMI input Type A , 4 x HDMI output Type A , 1 x TOSLINK output , 1 x audio output mini-jack stereo audio
External power adapter
Power Provided
DC 5 V - 1 A
AC 100-240 V
Electric Current Required
0.35 A
0.1 Watt
FCC, RoHS, WEEE, FCC Part 15 Class B, CAN ICES-3(B)/NMB3(B), ESD
18 cm
6.2 cm
1.4 cm
244 g
Shipping Width
21.2 cm
Shipping Depth
14.8 cm
Shipping Height
5.5 cm
Shipping Weight
500 g
20 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
GXJQ StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £16.49
GXJQ StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £21.31
GXJQ StarTech.com 10ft Ultra High Speed HDMI 2.1 In Stock £24.71
GXJQ StarTech.com 16ft Ultra High Speed HDMI 2.1 In Stock £40.48
GXJQ StarTech.com 2-Port HDMI Splitter, 4K 60Hz In Stock £51.31
Connectivity: HDMI
Ports: 4
