StarTech.com 4 Port Gigabit PoE PCIe NIC
Quicklinx: B1J7WS00 Mfr#: ST4000PEXPSE
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC, Unix
Type: Network adapter
£181.64 ex VAT
£217.96 inc VAT
Add 4 Gigabit Power over Ethernet ports to a PCI Express-enabled computer. The ST4000PEXPSE 4-Port PoE NIC lets you add four Gigabit Power over Ethernet ports through a single PCI Express slot. Each port can provide up to 25.5W of power, combining network data and power over a single Ethernet cable for reduced cable clutter and added convenience for remote PoE devices.
The PCI express PoE card supports the IEEE 802.3at (Type 1 and 2) standard for Power Sourcing Equipment (PSE), and can deliver up to 48V DC power to compliant Powered Devices (PD). This eliminates the need for a separate power source and data connection for PoE devices such as IP cameras, IP phones or wireless access points.
Suitable for any standard profile PCIe-enabled client, server or workstation, the PoE network card supports features such as Jumbo Frames (up to 9KB), VLAN tagging and Wake on LAN (WoL).
StarTech.com 4 Port Gigabit PoE PCIe Network Card - PSE PCI Express NIC - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x4
Ports
Gigabit Ethernet x 4
12 cm x 24 cm x 1.8 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
RTL8111E - Realtek Semiconductor
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Network adapter
Plug-in card
PCI Express x4
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
PoE, link/activity
Full duplex capability, power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), Jumbo Frames support, 48KB packet buffer
Processor / Memory
4 x 1000Base-T (PoE) - RJ-45 (external) , 1 - 4 PIN internal power (internal) , 1 - 15 pin Serial ATA power (internal)
FCC, RoHS
Software Included
Drivers & Utilities
12 cm
24 cm
1.8 cm
55 °C
10 - 90% (non-condensing)
B1J7 StarTech.com 10 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £3.83
B1J7 StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable In Stock £239.80
B1J7 StarTech.com Dual Port PCI Express Gigabit Ethernet PCIe Network Card Adapter - PoE/PSE In Stock £102.46
B1J7 StarTech.com 6 Port Industrial Gigabit Ethernet Switch, 4 PoE+ Ports and Voltage Regulation In Stock £222.40
B1J7 StarTech.com 8 Port Unmanaged Industrial Gigabit Power over Ethernet Switch - 802.3af/at PoE+ Switch In Stock £214.04
B1J7 StarTech.com Dual Port Gigabit PCI Express Server Network Adapter Card - PCIe NIC In Stock £63.09
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 150 - 300
