StarTech.com 4 Port Gigabit PoE+ Injector
Quicklinx: B90TWS00 Mfr#: POEINJ4G
£119.31 ex VAT
£143.17 inc VAT
Deliver power and data to four Power over Ethernet devices using this wall-mountable PoE+ midspan hub. This Gigabit midspan PoE+ injector is a cost-effective alternative to upgrading your existing network switch to a PoE-capable model.
It supplies up to 30 Watts output to each port, so you can easily power and access up to four high-power PoE-compliant devices - such as IP cameras - using standard Ethernet cable.
This versatile midspan PoE+ injector is suited for almost all PoE device classes, including wireless access points, as well as IP phones and cameras. The high-power PoE+ injector offers 120W total power distribution and delivers full power - up to 30.8W - from each port. Now, you can easily scale and power your PoE+ devices across long distances, even in remote locations where a typical power outlet is unavailable.
Plus, the cost-effective Power over Ethernet+ injector lets you connect your PoE-powered devices (PDs) to a non-PoE-capable switch, avoiding the expense and aggravation of upgrading your existing switch to a PoE-enabled model.
This injector is the perfect solution for a variety of environments. It features a wall-mountable rugged metal casing, but is palm-sized making it perfect for desktop placement too.
With plug-and-play operation, you can enjoy fast and hassle-free setup without disrupting your workflow.
Not sure which class your PoE devices are? The Gigabit midspan PoE+ injector automatically detects the power requirements of your PoE PDs, and delivers the appropriate level of power without damaging your devices.
With integrated circuit protection between each port, your devices are also protected from power interference.
  • Efficient power delivery
    This PoE injector provides up to 120 W of power, ensuring efficient operation of powered devices while simplifying cable management.
  • Robust construction
    Constructed with a metal housing, this injector is designed to withstand wear and tear in demanding environments.
  • Adaptable installation
    The wall-mountable design allows for versatile installation options, making it suitable for various locations and setups.
  • Compliance with standards
    Fully compliant with FCC and RoHS, this injector adheres to important environmental and safety standards.
  • Long operational lifespan
    With a mean time between failures of 50,000 hours, this device ensures reliability for critical applications.
StarTech.com 4 Port Gigabit Midspan - PoE+ Injector - 802.3at and 802.3af - Wall-mountable Power over Ethernet Midspan (POEINJ4G) - PoE injector - 120 Watt
PoE injector - external
Power Over Ethernet (PoE)
PoE+
220 g
Input Voltage
AC 100-240 V
Power Capacity
120 Watt
9.7 cm x 7 cm x 2.6 cm
P/N: POEEXT1GAT, POEEXT2GAT, ST12MHDLANU
PoE+ (IEEE 802.3at)
Input Voltage
AC 100-240 V
Power Capacity
120 Watt
4 x Gigabit LAN - RJ-45
3 x power cable
MTBF
50,000 hours
Wall mountable, metal housing
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3at, FCC, RoHS
50 °C
5 - 90% (non-condensing)
9.7 cm
7 cm
2.6 cm
220 g
B90T StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable In Stock £349.44
B90T StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £31.89
B90T StarTech.com 4 Port Gigabit PoE+ Injector In Stock £119.31
B90T StarTech.com 4-Port PoE+/PoE++ Injector 95W In Stock £252.21
Type: Power Injector
