StarTech.com 4-Port GbE SFP Network Card
Quicklinx: HFP2WS00 Mfr#: P041GI-NETWORK-CARD
Wired / Wireless: Wired
Protocol: Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Network adapter
£186.30 ex VAT
£223.56 inc VAT
Add up to four 1GbE SFP modules to a PCI Express (PCIe) 2.0 x2 (or higher) slot in an IT Administrator workstation or server backplane, using this 4-Port SFP Network Controller.
  • High Performance Intel Chipset
    The network controller features an Intel I350 chip known for its reliability and high-performance capabilities, offering low-latency and low CPU utilization, ensuring smooth and efficient network data transfer, which is critical for business applications and services. Support for VMDq, SR-IOV, and Intel VT-c technologies allow for enhanced virtual machine performance, reduced CPU overhead, and improved network virtualization capabilities. The PCIe network card supports PXE boot, enabling centralized operating system deployment and updates. It also features 9K jumbo frame support, reducing packet overhead for improved data transmission efficiency. VLAN tagging support allows for efficient network management and segmentation.
  • Hardware and Operating System Compatibility
    The network interface controller connects to an available x2 PCI Express 2.0 (or higher) expansion slot. It is compatible with Windows Server 2012 and newer, Windows 10 and newer, Linux, VMware ESXi 7.x, and Microsoft Hyper-V. This NIC is compatible with both MSA-compliant and branded 1GB SFP modules, as well as direct attach copper cables (DACC).
  • Flexible Network Connections
    The card features four SFP slots for interchangeable SFP modules. Select fiber transceiver modules that best suit the network needs of the application, based on the distance and connector type. StarTech.com offers a wide variety of SFP transceiver modules to meet many GbE network applications.
StarTech.com 4-Port GbE SFP Network Card, PCIe 2.0 x2, Intel I350-AM4 4x 1GbE Controller, 1000BASE Copper/Fiber Optic, Quad-Port Gigabit Ethernet NIC, Desktop/Server Backplanes - Windows and Linux Compatible (P041GI-NETWORK-CARD) - network adapter - PCIe 2.0 x2 - Gigabit SFP x 4
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x2
PCI Specification Revision
PCIe 2.0, PCIe 2.1
Ports
Gigabit SFP x 4
1 cm x 16.7 cm x 8.3 cm
Cabling Type
Ethernet 1000Base-LX, Ethernet 1000Base-SX, Ethernet 1000Base-T, Ethernet 1000Base-KX
1GbE
Data Transfer Rate
1 Gbps
Jumbo frame size: 9000
Network / Transport Protocol
TCP/IP, UDP/IP, IPv4, IPv6
Intel I350-AM4
IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ap, IEEE 802.3az, IEEE 802.11ax
Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Hyper-V Server, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Microsoft Windows 10 / 11, VMware ESXi 7.x, Linux 2.4.x or later (LTS versions only)
Network adapter
Plug-in card
PCI Express 2.0 x2
PCIe 2.0, PCIe 2.1
Ports
Gigabit SFP x 4
Wired
Cabling Type
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Status Indicators
Link/activity, link/speed
Full duplex capability, VMDq, SR-IOV, VT-c, Link Aggregation, DDM, EEE, VLAN Tagging, promiscuous mode, with heat sink, Auto MDIX, PXE boot, bus powered
Processor / Memory
Intel I350-AM4
4 x 1000Base-LX/SX - SFP (mini-GBIC)
FCC, WEEE, MSA, EMI
3.5 Watt
1 cm
16.7 cm
8.3 cm
Shipping Width
3.8 cm
Shipping Depth
20.7 cm
Shipping Height
14.4 cm
Shipping Weight
135 g
50 °C
5 - 90% RH (non-condensing)
HFP2 StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £40.09
HFP2 StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £23.89
HFP2 StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) In Stock £24.50
HFP2 StarTech.com 1-Port GbE SFP Network Card In Stock £86.39
HFP2 StarTech.com 2-Port GbE SFP Network Card In Stock £121.93
