The SV431DDVDUA 4-port DVI VGA dual monitor KVM switch lets you control 4 Dual Display computers using a single USB mouse and keyboard peripheral set.
This dual view KVM switch provides 1 VGA and 1 DVI-I port per computer connection for high-resolution video, as well as audio switching capability between connected computers.
The DVI/VGA KVM switch features an integrated 2-port USB hub that allows USB 2.0 peripherals to be shared between connected computers, and offers a compact design with a rugged metal chassis for durable performance.
While both DVI-I (analog) and DVI-D (digital) are supported by the KVM, source PCs must output the same signal for proper switching. It is recommended wherever possible to use DVI-D cables across all PC to KVM and KVM to Console connections.
Efficient management of multiple devices
The 4 Port DVI VGA Dual Monitor KVM Switch allows a single user to control up to four connected devices, enabling seamless transitions between systems without the need for multiple keyboards and mice. -
High video resolution support
This KVM switch supports a maximum video resolution of 1920 x 1440, ensuring that users can enjoy sharp and vibrant visuals for both work and entertainment. -
Convenient USB hub integration
Featuring a built-in 2-port USB 2.0 hub, this device provides users with extra connectivity for various peripherals, minimizing clutter and enhancing workflow. -
Versatile operating temperatures
With an operating temperature range of 0°C to 40°C, this KVM switch can function effectively in different environments, making it reliable for both professional and personal use. -
Compliant with standards
Having received FCC and RoHS compliance, this product meets necessary safety and environmental guidelines, assuring users of its quality and reliability.
- StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio and USB 2.0 Hub (SV431DDVDUA) - KVM / audio / USB switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Built-in 2-port USB 2.0 hub, HDCP compliant
- 22 cm x 13 cm x 6 cm
- 1.2 kg
- Black
- 3-year warranty
- Designed For
- P/N: IM12D1500P, SV431RACK, SVA12M2NEUA, SVA12M5NA, USBDVI4N1A10, USBDVI4N1A6, USBVGA4N1A10, USBVGA4N1A6
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1440
- 1 x VGA HD-15 , 1 x DVI-D , 4 x USB 2.0 Type A , 2 x audio mini-jack , 4 x VGA HD-15 , 4 x DVI-D , 4 x audio mini-jack , 4 x USB 2.0 Type B
- Power Device
- External power adapter
- Black
- FCC, RoHS
- 22 cm
- 13 cm
- 6 cm
- 1.2 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- Designed For
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £249.28 |
StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £115.65 |
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £131.32 |
StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) | In Stock | £22.32 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.56 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £2.97 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.73 |
StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub | In Stock | £128.71 |
StarTech.com 2-port Dual VGA KVM Switch | In Stock | £67.05 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.71 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £44.06 |
StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display | In Stock | £481.26 |
