This 4 port DVI USB KVM Switch lets you control four USB enabled, DVI capable computers from a single USB keyboard and mouse peripheral set. Ideal for multimedia applications, the switch supports audio and microphone switching, allowing you to switch between audio/mic channels either independently or simultaneously when switching between computers for KVM control. The DVI USB KVM switch features an integrated USB 2.0 hub which allows you to use shared USB peripherals from the control point as if the devices were connected directly to the slave computers - an economical solution that lets you use USB peripherals between computers (when selected) without the expense of buying individual peripherals for each slave computer.
- StarTech.com 4 Port DVI USB KVM Switch with Audio and 2 port USB 2.0 Hub - KVM / audio / USB switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- 25.3 cm x 11.5 cm x 4.5 cm
- 1.7 kg
- Black
- Localisation
- United Kingdom
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1440 @ 70 Hz
- Built-in Devices
- USB Hub
- Status Indicators
- Port status
- 4 x USB 2.0 Type B , Display / video: 4 x DVI-Digital - 18+5 pin combined DVI (Single-Link) , 4 x audio output mini-jack , 4 x microphone input mini-jack , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , Display / video: 1 x DVI-Digital - 18+5 pin combined DVI (Single-Link) , 2 x USB 2.0 Type A , 1 x audio output mini-jack , 1 x microphone input mini-jack
- Power Device
- External power adapter
- Black
- Localisation
- United Kingdom
- 25.3 cm
- 11.5 cm
- 4.5 cm
- 1.7 kg
- Limited warranty - 3 years
StarTech.com 6 ft 4-in-1 USB DVI KVM Cable with Audio and Microphone | In Stock | £7.39 |
StarTech.com 4 Port DVI USB KVM Switch with Audio & USB Hub | In Stock | £176.65 |
StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) | In Stock | £23.35 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.88 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £13.93 |
