StarTech.com 4-port Dual VGA KVM Switch
Quicklinx: BGBYWS00 Mfr#: SV431DVGAU2A
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 4
£162.38 ex VAT
£194.85 inc VAT
Control four Dual VGA, USB-equipped PCs with a two monitor console and audio peripheral set. This USB KVM lets you connect four computers, each with dual VGA outputs, to a dual-monitor workstation. You can switch the workstation between each computer, as well as two additional USB peripheral devices and 3.5mm speakers & microphone.
With support for two VGA video inputs and four different computers, this KVM switch maximizes productivity. Not only can you access multiple computers, but you can also use two VGA monitors on each computer streaming independent content to each display, which gives you the freedom to multitask and increase your productivity. The VGA ports support resolutions up to 1920x1200 for maximum screen viewing space.
Featuring dual video and support for your keyboard and mouse, along with a 2-port USB hub for additional peripheral devices, this KVM switch is perfect for accessing four separate systems using the same workstation. Support for your workstation plus two additional peripheral devices makes this KVM ideal for server control, simplifying access to multiple computer systems.
This 4-port KVM ensures effortless operation with intuitive hotkey control. It provides a simple yet comprehensive solution for switching between each connected computer and also supports manual operation using the easy-to-access buttons located on the front of the switch.
  • Maximize productivity with dual video
  • Multi-system access
  • Hassle-free operation
    This 4 port KVM ensures effortless operation with intuitive hotkey control. It provides a simple and comprehensive solution for switching between each connected computer and also supports manual operation using the easy-to-access buttons located on the front of the switch.
StarTech.com 4 Port VGA KVM Switch - Dual VGA - Hot-key & Audio Support - 1920x1200 KVM Switch - KVM Video Switch (SV431DVGAU2A) - KVM / audio / USB switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub, metal housing
AC 120/230 V
22 cm x 13 cm x 6 cm
1.236 kg
P/N: SV431RACK, SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200
4 x USB Type B , 8 x VGA input HD-15 , 4 x audio / headphones mini-jack , 4 x microphone input mini-jack , 2 x USB 2.0 Type A , 2 x VGA output HD-15 , 1 x audio / headphones mini-jack , 1 x microphone input mini-jack , 2 x keyboard (USB) / mouse (USB) Type A
External power adapter
AC 120/230 V
Rack Mounting Kit
Optional
FCC, RoHS
22 cm
13 cm
6 cm
1.236 kg
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
BGBY StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £86.26
BGBY StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £256.34
BGBY StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £253.13
BGBY StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £74.93
BGBY StarTech.com DisplayPort USB KVM Switch In Stock £292.14
BGBY StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £23.32
BGBY StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.99
BGBY StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.83
BGBY StarTech.com 3.5 Right Angle Stereo Cable In Stock £4.27
BGBY StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.11
BGBY StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
BGBY StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display In Stock £494.89
Connectivity: KVM
Ports: 4
