StarTech.com 4 Port Dual Monitor DVI KVM
Quicklinx: F07LWS00 Mfr#: SV431DD2DU3A
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 4
£266.96 ex VAT
£320.35 inc VAT
The TAA compliant Dual-Monitor DVI KVM Switch controls four multimedia computer systems from one dual-DVI monitor workstation.
The KVM switch supports four separate multimedia computer systems and the use of a dual DVI-D single-link monitor workstation, increasing productivity by enabling you to access more information at once.
The 2-port hub that's built into the USB 3.0 KVM switch shares two additional peripherals (in addition to keyboard and mouse) among attached computers as if they were directly connected while supporting high-performance peripherals such as flash drives and video capture devices.
With support for separate stereo audio and microphones, the KVM switch box connects everything you need directly to your systems, saving you money and desk space.
The front-panel push-buttons make it easy to switch between systems and activate the auto-scan feature. The hotkey functionality makes accessing each system quickly, while an optional buzzer sound confirms the switch.
StarTech.com offers a wide selection of high-quality KVM switches and KVM-related products to help you access your systems more efficiently without the expense and clutter of extra keyboards, mice, and monitors.
StarTech.com 4 Port Dual Monitor DVI KVM Switch - Dual Screen Display Compact USB KVM Switch with USB 3.0 Hub & Audio - TAA Compliant - KVM / audio / USB switch - 4 ports - TAA Compliant
Subtype
KVM
Ports
4 x KVM / audio / USB
AC 120/230 V 0.8 A
25.3 cm x 10 cm x 6.6 cm
1.3 kg
Australia, Japan, New Zealand, North America, United Kingdom, Europe
TAA Compliant
Subtype
KVM
Ports
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536 @ 85 Hz
Built-in Devices
USB 3.0 hub
4 x USB 3.1 Type B , 8 x DVI-I 24+1 pin digital DVI , 4 x microphone mini-jack , 4 x headphones / speakers mini-jack , 2 x USB 3.0 Type A , 2 x USB 1.1 Type A , 2 x DVI-I 24+1 pin digital DVI console , 1 x microphone mini-jack console , 1 x headphones / speakers mini-jack console
External power adapter
Power Provided
DC 9 V - 2 A
AC 120/230 V
Electric Current Required
0.8 A
18 Watt
TAA Compliant
25.3 cm
10 cm
6.6 cm
1.3 kg
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Humidity Range Storage
F07L StarTech.com 2 Port Dual Monitor HDMI KVM Switch In Stock £306.74
F07L StarTech.com 2 Port HDMI KVM Switch In Stock £234.56
F07L StarTech.com 4 Port HDMI KVM Switch In Stock £315.75
F07L StarTech.com 2 Port Triple Monitor DisplayPort KVM Switch In Stock £351.85
F07L StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch In Stock £457.28
Connectivity: KVM
Ports: 4
