StarTech.com 4 Port Dual DVI USB KVM Switch with Audio
Quicklinx: 67CWWS00 Mfr#: SV431DVIDGB
This 4 Port Dual DVI USB KVM Switch allows four PCs, each with dual DVI displays, to share two monitors, one microphone (and set of speakers), one keyboard and one mouse as well as two other USB peripherals.
An ideal solution for graphic designers, CAD/CAM designers or educational and financial institutions, the Dual View KVM Switch allows you to instantly switch back and forth between PCs at the touch of a button while maintaining professional level video quality on both DVI monitors, in turn saving money by eliminating redundant peripheral purchases.
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio - KVM / audio / USB switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub, HDCP compliant
25.3 cm x 10 cm x 6.6 cm
United Kingdom
1-year warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
Status Indicators
Port status
4 x keyboard (USB) / mouse (USB) Type B , 8 x DVI-I , 4 x microphone mini-jack , 4 x speakers mini-jack , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 2 x DVI-I , 2 x USB 2.0 Type A , 1 x microphone mini-jack , 1 x speakers mini-jack
External power adapter
FCC, RoHS
United Kingdom
Software Included
Drivers & Utilities
25.3 cm
10 cm
6.6 cm
Limited warranty - 1 year
0 - 90%
