StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub
Quicklinx: 6LCYWS00 Mfr#: SV431DD2DUA
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 4
Hurry, only 1 left in stock!
£233.24 ex VAT
£279.88 inc VAT
Share a keyboard, mouse and dual DVI displays/monitors between 4 multimedia computers. The SV431DD2DUA 4-port Dual DVI USB KVM Switch allows up to four PCs, each with dual DVI video outputs, to share two monitors, one microphone and set of speakers, one keyboard and one mouse as well as two other USB peripherals.
An ideal solution for graphic designers, CAD/CAM designers or educational and financial institutions, the dual view KVM Switch allows you to instantly switch back and forth between dual DVI display PCs at the touch of a button, while maintaining professional level video quality on both monitors. The dual DVI switch also features an integrated USB hub port that allows USB 2.0 peripherals such as thumb drives, external hard drives or web cams to be shared between attached systems - eliminating duplicate peripheral costs.
While both DVI-I (analog mode) and DVI-D (digital only) are supported by the KVM, both source PCs should output the same signal type for proper switching. It is recommended wherever possible to use DVI-D cables across all PC to KVM and KVM to Console connections.
StarTech.com 4-Port Dual KVM Switch with Audio for DVI Computers - Built-in USB Hub (SV431DD2DUA) - KVM / audio / USB switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub
22 cm x 13 cm x 6 cm
1.2 kg
3-year warranty
P/N: IM12D1500P, SV431RACK, SVA12M2NEUA, SVA12M5NA, USBDVI4N1A10, USBDVI4N1A6
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
8 x DVI-I , 4 x keyboard (USB) / mouse (USB) Type B , 4 x microphone mini-jack , 4 x speakers mini-jack , 2 x DVI-I , 1 x microphone mini-jack , 1 x speakers mini-jack , 2 x keyboard (USB) / mouse (USB) Type A , 2 x USB 2.0 Type A
External power adapter
FCC, RoHS
22 cm
13 cm
6 cm
1.2 kg
Limited warranty - 3 years
6LCY StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £233.24
6LCY StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £243.20
6LCY StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £114.49
6LCY StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.50
6LCY StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £22.12
6LCY StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.00
6LCY StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.48
6LCY StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.06
6LCY StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.78
6LCY StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.65
6LCY StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub In Stock £124.31
6LCY StarTech.com 2-port Dual VGA KVM Switch In Stock £67.05
6LCY StarTech.com DC Power Adapter - 12V, 2A In Stock £11.71
6LCY StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
6LCY StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display In Stock £469.52
Connectivity: KVM
Ports: 4
