Share and switch between four USB-A and DisplayPort-enabled computers, using this DisplayPort KVM Switch. Share an 8K 60Hz DisplayPort monitor, a keyboard and mouse, two USB 5Gbps devices, and two additional USB 2.0 devices.
                High-Resolution 8K 60Hz VideoThis KVM supports resolutions up to 8K 60Hz or 4K 144Hz/120Hz. Daisy chain additional monitors via MST pass-through. The KVM supports ultrawide resolutions of up to 5120x1440 at 60Hz. Ideal for applications such as CAD/CAM, video editing, and content creation. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and greater luminosity.
                Customizable SwitchingThis Universal KVM Switch provides various switching options, including hotkey or push-button switching. Hotkeys allow for independent switching of audio and video, enabling audio playback from one computer while controlling another. An audible buzzer confirms hotkey input, and LEDs provide a visual status of the selected host.
                Universal CompatibilityThe TAA-Compliant KVM Switch offers universal compatibility, working with all operating systems, including Windows, macOS, ChromeOS, and Linux. It is also compatible with all hardware platforms, including Intel and AMD.
                Reliable PerformanceThe durable metal housing helps prevent Electro-magnetic Interference (EMI). Overcurrent Protection (OCP) ensures peripherals don't overdraw power, reducing the occurrence of device dropouts or shutdowns.
- StarTech.com 4-Port DisplayPort 1.4 KVM Switch, 8K 60Hz / 4K 144Hz, 2x USB 3.0 Ports, 4x USB 2.0 Ports, Hotkey Switching, TAA Compliant (D86A2-4-PORT-8K-KVM) - KVM / audio / USB switch - 4 ports - TAA Compliant
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Performance
- Data transfer rate: 5 Gbps
- Metal housing, push button, hotkeys
- Power
- AC 100-240 V 1 A
- 13 cm x 22 cm x 4.4 cm
- 1 kg
- Black
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Performance
- Max Resolution
- 7680 x 4320 @ 60 Hz
- Metal housing, push button, hotkeys, Auto Scan mode, ultrawide resolutions support
- Status Indicators
- Power
- 1 x DisplayPort output , 4 x DisplayPort input , 2 x USB 3.0 Type A , 4 x USB 2.0 Type A , 4 x USB 3.2 Gen 1 input Type B , 4 x audio input mini-jack , 1 x audio output mini-jack
- Power Device
- External power adapter
- Power Provided
- 3 A
- Voltage Required
- AC 100-240 V
- Electric Current Required
- 1 A
- 36 Watt
- Black
- Included Accessories
- 4 rubber feet
- MTBF
- 130,000 hours
- FCC Part 15, RoHS, DisplayPort 1.4, DSC, HDCP
- TAA Compliant
- 13 cm
- 22 cm
- 4.4 cm
- 1 kg
- Shipping Width
- 40.9 cm
- Shipping Depth
- 21.2 cm
- Shipping Height
- 8.7 cm
- Shipping Weight
- 1.6 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 85% RH (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
|  | StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.78 |
|  | StarTech.com 3ft DisplayPort 1.4 8K 60Hz | In Stock | £13.82 |
|  | StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £14.98 |
|  | StarTech.com 10ft DisplayPort 1.4 8K 60Hz | In Stock | £20.57 |
|  | StarTech.com 2-Port DP KVM Switch, 8K 60Hz | In Stock | £297.72 |
|  | StarTech.com 4-Port DisplayPort KVM Switch | In Stock | £351.85 |
|  | StarTech.com Dual-Monitor DP 1.4 KVM Switch | In Stock | £389.32 |
|  | StarTech.com 2-Port DisplayPort KVM Switch | In Stock | £292.80 |
