StarTech.com 4-Port Charging Station for USB Devices - 48W/9.6A
Quicklinx: BWGFWS00 Mfr#: ST4CU424UK
Hurry, only 1 left in stock!
£36.58 ex VAT
£43.89 inc VAT
Express delivery Order within the next 19 hours for delivery on Thursday
Charge up to four mobile devices at the same time, from a central location. This USB charging station offers a high-powered solution for keeping your mobile devices powered and ready for use. It's compatible with a wide range of tablets and smartphones, and features built-in safety measures to help protect against damage to your mobile devices.
The charging station can deliver 48 watts of power in total, providing 2.4 amps of power per port. That means you can charge four tablets at once, and every port can provide the power each device needs.
The charger supports USB Battery Charging Specification 1.2, which ensures compatibility with a broad range of mobile devices, including the Apple iPhone and iPad, the Microsoft Surface tablet, the Samsung Galaxy Tab, Android devices and more.
This all-in-one charger is perfect for charging multiple devices during meetings in a boardroom or conference room. It gives you and your co-workers access to charging when it's needed. Plus, consolidating your USB devices onto a single multi-port USB charger offers a more efficient solution and saves space. You don't need to use multiple wall outlets or power bars.
The compact, metal enclosure is extremely durable and offers simple operation, using an integrated on/off power button that turns all ports on and off. For further flexibility, the charge station includes a bracket for wall-mounted installations.
The USB charging station features built-in safety measures to ensure that all of your devices are protected against damage from overheating, overvoltage, overcurrent or short circuiting. If the 48-watt limit is exceeded, the power being sent to the connected devices will turn off, and the charger will reset itself until the load is reduced to safe levels.
The charger also includes an LED indicator beside each port to notify you of a short circuit, while the affected port will shut down until you power-cycle the charger.
StarTech.com 4-Port Charging Station for USB Devices - 48W/9.6A power adapter
Power adapter
6 cm x 9.5 cm x 2.5 cm
128 g
Output Connector Type
USB
AC 100-240 V
Voltage Provided
12 V
Power Device Details
- 4 pin USB Type A - 2.4 A
Power adapter
6 cm
9.5 cm
2.5 cm
128 g
Enclosure Colour
AC 100-240 V
Voltage Provided
12 V
Output connectors
Total 4: 4 pin USB Type A
Power Provided
48 Watt
Max Electric Current
9.6 A
Short circuit protection, overheat protection, over voltage protection, over-current protection, on/off button, power LED Indicator, 4 short circuit fault LED indicators beside each port
4 mounting screws, 2 wall mount brackets, 2 rubber feet
FCC, RoHS, USB Battery Charging Specification Rev. 1.2
Price Range Ex VAT: 0 - 50
