Turn a single USB 2.0 port into 4 external USB 2.0 ports.
This 4 Port USB 2.0 Hub connects to one USB 2.0 port on a Mac or PC computer, adding four USB 2.0 ports - allowing you to maximize the number of high speed USB peripherals connected to your computer. The hub supports cascaded installation with other USB 2.0 hubs, supporting up to 127 USB 2.0 device connections - a scalable solution for connecting multiple USB devices to a single host computer.
The 4 port hub includes a power adapter, but can be powered through USB bus connection to the host computer - allowing you to install the hub as needed without worrying about the availability of a power outlet.
The USB 2.0 hub offers an attractive black casing that suits any operating environment and includes a 3ft USB 2.0 A/B male-male cable, for the connection between the hub and the host computer.
Convenient connectivity
Equipped with four USB 2.0 ports, this hub allows connection of multiple devices simultaneously, enhancing productivity for users. -
Simple installation
The Plug-and-Play feature eliminates the need for complicated setups, making it easy to connect devices quickly. -
Reliable performance
With an operating temperature range of 0°C to 70°C, this hub maintains stable functionality across various environments. -
Mac compatibility
Designed specifically for Mac systems, this hub ensures seamless integration with compatible devices. -
Environmentally responsible
Complying with FCC and RoHS standards, this USB hub prioritizes safe usage and environmental sustainability.
- StarTech.com 4 Port USB 2.0 Hub - Hub - 4 ports - Hi-Speed USB - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x USB 2.0
- USB 1.1, USB 2.0
- 6.8 cm x 9.7 cm x 1.9 cm
- Black
- System Requirements
- Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003
- Localisation
- United Kingdom
- 1-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 4 x USB 2.0
- USB 1.1, USB 2.0
- Status Indicators
- Power
- 4 x USB 2.0 Type A , 1 x USB 2.0 Type B
- Power Device
- External power adapter
- Black
- Cables Included
- 1 x USB cable - 91 cm
- Plug and Play, FCC, RoHS
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 6.8 cm
- 9.7 cm
- 1.9 cm
- Limited warranty - 1 year
- 0 °C
- 70 °C
StarTech.com 4 Port Black USB 2.0 Hub | In Stock | £17.64 |
StarTech.com DC Power Adapter - 5V, 2A | In Stock | £9.67 |
