StarTech.com 4 Port Black USB 2.0 Hub
Quicklinx: 5FG0WS00 Mfr#: ST4202USBGB
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
Form Factor: External
£18.08 ex VAT
£21.69 inc VAT
Turn a single USB 2.0 port into 4 external USB 2.0 ports.
This 4 Port USB 2.0 Hub connects to one USB 2.0 port on a Mac or PC computer, adding four USB 2.0 ports - allowing you to maximize the number of high speed USB peripherals connected to your computer. The hub supports cascaded installation with other USB 2.0 hubs, supporting up to 127 USB 2.0 device connections - a scalable solution for connecting multiple USB devices to a single host computer.
The 4 port hub includes a power adapter, but can be powered through USB bus connection to the host computer - allowing you to install the hub as needed without worrying about the availability of a power outlet.
The USB 2.0 hub offers an attractive black casing that suits any operating environment and includes a 3ft USB 2.0 A/B male-male cable, for the connection between the hub and the host computer.
  • Convenient connectivity
    Equipped with four USB 2.0 ports, this hub allows connection of multiple devices simultaneously, enhancing productivity for users.
  • Simple installation
    The Plug-and-Play feature eliminates the need for complicated setups, making it easy to connect devices quickly.
  • Reliable performance
    With an operating temperature range of 0°C to 70°C, this hub maintains stable functionality across various environments.
  • Mac compatibility
    Designed specifically for Mac systems, this hub ensures seamless integration with compatible devices.
  • Environmentally responsible
    Complying with FCC and RoHS standards, this USB hub prioritizes safe usage and environmental sustainability.
StarTech.com 4 Port USB 2.0 Hub - Hub - 4 ports - Hi-Speed USB - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
USB 1.1, USB 2.0
6.8 cm x 9.7 cm x 1.9 cm
Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003
United Kingdom
1-year warranty
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 2.0
USB 1.1, USB 2.0
Status Indicators
4 x USB 2.0 Type A , 1 x USB 2.0 Type B
External power adapter
1 x USB cable - 91 cm
Plug and Play, FCC, RoHS
United Kingdom
Software Included
Drivers & Utilities
6.8 cm
9.7 cm
1.9 cm
Limited warranty - 1 year
70 °C
5FG0 StarTech.com 4 Port Black USB 2.0 Hub In Stock £18.08
5FG0 StarTech.com DC Power Adapter - 5V, 2A In Stock £9.91
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
