StarTech.com 4 Port Black SuperSpeed USB 3.0 Hub
Quicklinx: 7B7NWS00 Mfr#: ST4300USB3GB
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 4
Form Factor: External
£14.25 ex VAT
£17.10 inc VAT
The ST4300USB3GB 4-Port SuperSpeed USB 3.0 Hub allows you to add 4 additional USB 3.0 ports from a single USB 3.0 connection to the host computer system.
Backward compatible with USB 2.0 and USB 1.x standards, this USB 3.0 hub still supports older USB devices and can also be used as a hub on older systems that do not have USB 3.0 ports.
With the capability to mix and match USB 3.0/2.0/1.x devices and be used with or without the included external power adapter, this hub offers the best of versatility and portability.
  • Versatile connectivity options
    Equipped with four SuperSpeed USB 3.0 ports, this hub allows the connection of multiple devices at once, improving productivity and efficiency.
  • Easy Plug-and-Play setup
    The hub features a simple Plug-and-Play design, allowing users to connect devices without the hassle of additional drivers or software installations.
  • Robust operational range
    Designed to operate in a wide temperature range from 0°C to 50°C, this hub remains functional in various environments, accommodating diverse user needs.
  • Power adapter included
    An external power adapter is included to ensure consistent power supply, allowing users to charge connected devices while transmitting data.
StarTech.com 4-Port USB 3.0 SuperSpeed Hub with Power Adapter - Portable Multiport USB-A Dock IT Pro - USB Port Expansion Hub for PC/Mac (ST4300USB3) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB 1.1, USB 2.0, USB 3.0
6.8 cm x 9.5 cm x 2.3 cm
55 g
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition
United Kingdom
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Status Indicators
4 x USB 3.0 Type A , 1 x USB 3.0 Type B
External power adapter
Plug and Play, FCC, RoHS
United Kingdom
6.8 cm
9.5 cm
2.3 cm
55 g
50 °C
5 - 85%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
7B7N StarTech.com 4 Port Black USB 2.0 Hub In Stock £18.08
7B7N StarTech.com 7 Port Black USB 2.0 Hub In Stock £23.89
7B7N StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £61.41
7B7N StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £85.03
7B7N StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.76
7B7N StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.06
7B7N StarTech.com 4 Port Black SuperSpeed USB 3.0 Hub In Stock £14.25
7B7N StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
Type: USB Hub
Speed: 5Gbps
Ports: 4
