The ST4300USB3GB 4-Port SuperSpeed USB 3.0 Hub allows you to add 4 additional USB 3.0 ports from a single USB 3.0 connection to the host computer system.
Backward compatible with USB 2.0 and USB 1.x standards, this USB 3.0 hub still supports older USB devices and can also be used as a hub on older systems that do not have USB 3.0 ports.
With the capability to mix and match USB 3.0/2.0/1.x devices and be used with or without the included external power adapter, this hub offers the best of versatility and portability.
Versatile connectivity options
Equipped with four SuperSpeed USB 3.0 ports, this hub allows the connection of multiple devices at once, improving productivity and efficiency. -
Easy Plug-and-Play setup
The hub features a simple Plug-and-Play design, allowing users to connect devices without the hassle of additional drivers or software installations. -
Robust operational range
Designed to operate in a wide temperature range from 0°C to 50°C, this hub remains functional in various environments, accommodating diverse user needs. -
Power adapter included
An external power adapter is included to ensure consistent power supply, allowing users to charge connected devices while transmitting data.
- StarTech.com 4-Port USB 3.0 SuperSpeed Hub with Power Adapter - Portable Multiport USB-A Dock IT Pro - USB Port Expansion Hub for PC/Mac (ST4300USB3) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- USB 1.1, USB 2.0, USB 3.0
- 6.8 cm x 9.5 cm x 2.3 cm
- 55 g
- Black
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition
- Localisation
- United Kingdom
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Status Indicators
- Power
- 4 x USB 3.0 Type A , 1 x USB 3.0 Type B
- Power Device
- External power adapter
- Black
- Plug and Play, FCC, RoHS
- Localisation
- United Kingdom
- OS Required
- 6.8 cm
- 9.5 cm
- 2.3 cm
- 55 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 85%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
StarTech.com 4 Port Black USB 2.0 Hub | In Stock | £18.08 |
StarTech.com 7 Port Black USB 2.0 Hub | In Stock | £23.89 |
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £61.41 |
StarTech.com Mountable Rugged Industrial 7 Port USB Hub | In Stock | £85.03 |
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £27.76 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.06 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.01 |
