This 4 Port KVM Switch Kit lets you control four computers using a single keyboard, mouse and VGA monitor and offers both hotkey and top panel push-button operation for simple switching between connected computers.
Designed to integrate seamlessly into any environment, the KVM switch offers a small footprint design (roughly the size of a deck of playing cards) and draws power from the connected computers, so it doesn't require an external power supply.
A suitable solution for virtually any application, the KVM switch supports video resolutions of up to 2048 x 1536 and includes 3-in-1 (PS/2 and Video) cables to provide a complete, out-of-the-box KVM solution.
- StarTech.com 4 Port Black PS/2 KVM Switch Kit with Cables - 4 Port PS2 KVM Switch - KVM Switch with Cables - VGA KVM Switch (SV411K) - KVM switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Users Qty
- 1 local user
- 18 cm x 8.5 cm x 2 cm
- 2-year warranty
- Designed For
- P/N: SVECON6
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2
- Max Resolution
- 1920 x 1440
- Status Indicators
- Port status, power
- 4 x keyboard (PS/2) , 4 x mouse (PS/2) , 4 x VGA HD-15 , 1 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2)
- Cables Included
- 2 x keyboard / mouse / video cable - 1.8 m , 2 x keyboard / mouse / video cable - 1.2 m
- 18 cm
- 8.5 cm
- 2 cm
- Limited warranty - parts and labour - 2 years - carry-in
- Designed For
- P/N: SVECON6
StarTech.com 4 Port Black PS/2 KVM Switch Kit with Cables | In Stock | £56.48 |
StarTech.com 6 ft 3-in-1 Ultra Thin PS/2 KVM Cable | In Stock | £7.49 |
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub | In Stock | £94.41 |
StarTech.com 2 Port Professional PS/2 KVM Switch | In Stock | £48.31 |
StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz | In Stock | £85.19 |
StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable | In Stock | £102.14 |
Customer reviews
Write a review for the StarTech.com 4 Port Black PS/2 KVM Switch Kit with Cables here!
No regrets and very neat!
Reviewed by David Smith. Review Posted 30/01/2008
Bought this to replace a Belkin 4port switch which was very troublesome and unreliable most of the time. This is the complete opposite. In fact, we did a direct replacement from the Belkin to this whilst the machines were still on, and it picked them all up no problem!
PS/2 device cables are fed through the VGA monitor cable, so you only have 1 cable per each port as opposed to the conventional 3, which makes working areas much neater.
As for the guy who can't get widescreen working, I am using a widescreen with this KVM right now and it works perfectly fine with no signal degrading issues. Highly recommended.
- Overall
- Ease of use
- Value for money
Brilliant
Reviewed by Derrick. Review Posted 22/05/2007
I bought this product to replace a Belkin Omniview 4-way switch, which was nothing but trouble.
I've used the Startech for about a week, without a glitch. All of the problems I had with the Belkin have simply disappeared.
The price is unbelievable - you could easily pay this just for the cables, which are neater and more manageable than the traditional KVM cables. Cannot rate this product highly enough!
- Overall
- Ease of use
- Value for money
Great little unit!
Reviewed by stephen. Review Posted 03/09/2007
Does exactly what it is supposed to do. The build quality is great and it worked straight out of the box. The cables are nice and tidy and not too cumbersome.
I have used other KVMs and had nothing but problems, but this works just fine and all without the use of a PSU. Well worth the money.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
