This quad-port 2.5 GbE network interface card (NIC) features an Intel I225-V chipset with Intel vPro technology, to enhance performance and data integrity across four 2.5G ethernet connections. The variable multispeed options (2.5/1Gbps and 100/10Mbps) enable support for both new and legacy network hardware. Utilize existing Cat5e or CAT6 cabling infrastructure while adding NBASE-T (802.3bz) compatibility for seamless integration.
Increased Network Speed
The PCIe network card leverages Intel vPro technology for remote management and troubleshooting capabilities. Improve bandwidth for data-intensive applications, network sharing, FTPs, online or local storage/backup, and the streaming of online content - while reducing network slowdowns. Access up to 2.5GBASE-T speeds using Cat5e (or better) cabling, to maximize existing networks and equipment. -
Enhance Existing Hardware
The network interface card connects via an available x4 PCI Express 2.0 (or higher) expansion slot. The card ships in a standard-profile bracket and includes a low-profile bracket for installation into small form factor systems and servers. This ethernet NIC card is compatible with Windows, Windows Server, VMware, and Linux. This card supports the following advanced features: PXE Boot, WoL, VLAN tagging, 9 K jumbo frame, full-duplex, and Intel vPro technology.
- StarTech.com 4-Port 2.5Gbps NBASE-T PCIe Network Card, Intel I225-V Chip, Quad Port Computer Network Card, Multi-Gigabit NIC, PCI Express Server LAN Card, Desktop Ethernet Interface Card, PCI Express 2.0 (PR42GI-NETWORK-CARD) - network adapter - PCIe 2.0 x4 - 10M/100M/1G/2.5 Gigabit Ethernet x 4
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 2.0 x4
- PCI Specification Revision
- PCIe 2.0
- Ports
- 2.2 cm x 18 cm x 12 cm
- 100 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
- Data Transfer Rate
- 2.5 Gbps
- Capacity
- Jumbo frame size: 9000
- Processor
- Intel I225-V
- IEEE 802.3bz, IEEE 802.3ab, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1as, IEEE 802.1x, IEEE P802.3az
- Black
- System Requirements
- Microsoft Windows 10 / 11, Microsoft Windows Server 2019, Microsoft Windows Server 2022, VMware ESXi 7.0, Linux 5.8.x or later (LTS versions only)
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- PCIe 2.0
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
- 2.5 Gbps
- Capacity
- Status Indicators
- Link/activity, link/speed
- Full duplex capability, PXE boot, Auto MDIX, bus powered, WOL, Intel vPro Technology support, VLAN support, VLAN Tagging, auto-negotiation
Processor / Memory
- Processor
- Intel I225-V
- 4 x 2.5 GBase-T - RJ-45
- Included Accessories
- Low-profile bracket
- WEEE, FCC, IEEE 1588
- Black
- OS Required
- 2.2 cm
- 18 cm
- 12 cm
- 100 g
- Shipping Weight
- 130 g
- Limited warranty - 2 years , Technical support - assistance - lifetime
- 0 °C
- 55 °C
- 5 - 90% RH
StarTech.com 4-Port RJ45 1G OCP 3.0 NIC | In Stock | £256.92 |
