StarTech.com 4-Port 2.5G PCIe Network Card
Quicklinx: HDG8WS00 Mfr#: PR42GI-NETWORK-CARD
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Ethernet, Fast Ethernet, 2.5 Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Network adapter
£154.44 ex VAT
£185.32 inc VAT
This quad-port 2.5 GbE network interface card (NIC) features an Intel I225-V chipset with Intel vPro technology, to enhance performance and data integrity across four 2.5G ethernet connections. The variable multispeed options (2.5/1Gbps and 100/10Mbps) enable support for both new and legacy network hardware. Utilize existing Cat5e or CAT6 cabling infrastructure while adding NBASE-T (802.3bz) compatibility for seamless integration.
  • Increased Network Speed
    The PCIe network card leverages Intel vPro technology for remote management and troubleshooting capabilities. Improve bandwidth for data-intensive applications, network sharing, FTPs, online or local storage/backup, and the streaming of online content - while reducing network slowdowns. Access up to 2.5GBASE-T speeds using Cat5e (or better) cabling, to maximize existing networks and equipment.
  • Enhance Existing Hardware
    The network interface card connects via an available x4 PCI Express 2.0 (or higher) expansion slot. The card ships in a standard-profile bracket and includes a low-profile bracket for installation into small form factor systems and servers. This ethernet NIC card is compatible with Windows, Windows Server, VMware, and Linux. This card supports the following advanced features: PXE Boot, WoL, VLAN tagging, 9 K jumbo frame, full-duplex, and Intel vPro technology.
StarTech.com 4-Port 2.5Gbps NBASE-T PCIe Network Card, Intel I225-V Chip, Quad Port Computer Network Card, Multi-Gigabit NIC, PCI Express Server LAN Card, Desktop Ethernet Interface Card, PCI Express 2.0 (PR42GI-NETWORK-CARD) - network adapter - PCIe 2.0 x4 - 10M/100M/1G/2.5 Gigabit Ethernet x 4
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x4
PCI Specification Revision
PCIe 2.0
Ports
2.2 cm x 18 cm x 12 cm
100 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Data Transfer Rate
2.5 Gbps
Jumbo frame size: 9000
Intel I225-V
IEEE 802.3bz, IEEE 802.3ab, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1as, IEEE 802.1x, IEEE P802.3az
Microsoft Windows 10 / 11, Microsoft Windows Server 2019, Microsoft Windows Server 2022, VMware ESXi 7.0, Linux 5.8.x or later (LTS versions only)
Network adapter
Plug-in card
PCI Express 2.0 x4
PCIe 2.0
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
2.5 Gbps
Status Indicators
Link/activity, link/speed
Full duplex capability, PXE boot, Auto MDIX, bus powered, WOL, Intel vPro Technology support, VLAN support, VLAN Tagging, auto-negotiation
Processor / Memory
Intel I225-V
4 x 2.5 GBase-T - RJ-45
Low-profile bracket
WEEE, FCC, IEEE 1588
2.2 cm
18 cm
12 cm
100 g
Shipping Weight
130 g
Limited warranty - 2 years , Technical support - assistance - lifetime
55 °C
5 - 90% RH
HDG8 StarTech.com 1-Port 2.5G PCIe Network Card In Stock £34.71
HDG8 StarTech.com 4-Port RJ45 1G OCP 3.0 NIC In Stock £244.75
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: 2.5 Gigabit Ethernet
