This 4-port USB KVM Switch lets you control multiple USB based computers from a single console (USB keyboard, USB mouse, monitor).
The versatile USB KVM switch features convenient pushbutton and hot-key control for quick, reliable switching between connected computers.
A convenient and straight-forward control solution, the USB KVM switch supports both manual and auto-scan modes and simple configuration through the built-in OSD.
Designed to ensure maximum space-efficiency, the USB KVM switch features a slim 1U design that fits neatly into a server equipment rack/cabinet (with options mounting bracket) and offers rear cable connections to eliminate cable tangles.
- StarTech.com 4-Port USB KVM Swith with OSD - TAA Compliant - 1U Rack Mountable VGA KVM Switch (SV431DUSBU) - KVM switch - 4 ports
- KVM switch - 4 ports - cascadable
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Users Qty
- 1 local user
- On-Screen Display
- Power
- AC 120/230 V
- 22 cm x 13 cm x 4.3 cm
- 1.5 kg
- Black
- 3-year warranty
- Designed For
- P/N: IM12D1500P, RACKCOND17HD, RKCONS1701, SV431RACK, SVA12M2NEUA, SVA12M5NA, SVECONUS10, SVECONUS15, SVECONUS6, SVUSBVGA10, SVUSBVGA6
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1440
- On-Screen Display
- Status Indicators
- Port status, power
- 4 x KVM HD-15 , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Rack Mounting Kit
- Optional
- FCC, RoHS
- 22 cm
- 13 cm
- 4.3 cm
- 1.5 kg
- Limited warranty - 3 years
- 5 °C
- 40 °C
- Designed For
