StarTech.com 4 Independent Port PCI Express PCIe USB 3.0 Controller Card Adapter with UASP
Quicklinx: 8JFGWS00 Mfr#: PEXUSB3S400
  • Windows 8 (32/64 bits)
Add 4 Independent SuperSpeed USB 3.0 ports to your PC through a PCI Express slot. The PEXUSB3S400 PCI Express USB 3.0 Card adds 4 independent external USB 3.0 ports to any PCI Express x4-enabled computer system, with full bandwidth support (up to 5Gbps) per port when connected to USB 3.0 devices. Unlike other USB 3.0 cards, which share the maximum bandwidth between multiple ports, the card offers maximum transfer rates to each device when multiple devices are connected.
Further enhanced with UASP support (USB Attached SCSI Protocol), this USB 3.0 controller performs up to 70% faster than conventional USB 3.0 when paired with a UASP supported enclosure (Note: UASP requires a compatible operating system). Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP technology optimizes transfers by allowing multiple commands to be processed simultaneously, significantly increasing transfer speeds for less wait time on data transfers.
This 4-port USB 3.0 card features a stacked port layout, which places the ports one on top of the other, so more ports are able to fit into a smaller space. Plus, with a built-in SATA power connector, each USB port can provide up to 900mA of power to devices that draw power from a host bus connection (500mA for USB 2.0) by connecting to your computer power supply.
UASP is supported in Windows 8, Server 2012 and Linux kernel 2.6.3 or later. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources.
Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
StarTech.com 4 Independent Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with SATA Power - USB adapter - PCIe x4 - USB 3.0 x 2
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x4
Ports
USB 3.0 x 2
1.9 cm x 17.1 cm x 6 cm
73.2 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
NEC uPD720202
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
P/N: S3510BMU33, S3510SMU33, S3520BU33ER, S352BU313R, SATDOCK2REU3, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U33, SDOCKU33BV, SDOCKU33EBV, ST3300U3S, USB31000S2H, USB31000SA, USB3HDCAP, USB3S2ESATA3, USB3S2SAT3CB
USB adapter
PCI Express x4
Ports
USB 3.0 x 2
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
Processor / Memory
NEC uPD720202
2 x USB 3.0 - 9 pin USB Type A
Compatible Slots
1 x PCI Express x4
Low-profile bracket
WHQL, FCC, RoHS
Software Included
Drivers & Utilities
1.9 cm
17.1 cm
6 cm
73.2 g
5 °C
85 °C
20 - 80%
