StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock
Quicklinx: 7P25WS00 Mfr#: SATDOCK4U3RE
£416.23 ex VAT
£499.47 inc VAT
Duplicate one SATA Hard Drive onto three Hard Drives simultaneously.
The SATDOCK4U3RE USB 3.0 and eSATA 1-to-3 Hard Drive Duplicator docking station enables you to duplicate/clone a single SATA hard drive to up to three other SATA drives simultaneously, as a standalone device. The duplicator can also function as a regular 4-bay hard drive docking station, by connecting to a host computer system. Large capacity drives (tested with up to 4TB 3.5" and 1TB 2.5" drives per bay) can be used to greatly enhance your computer's storage/backup capabilities.
Able to perform 1:3 sector duplication, including HPA, from a single SATA drive onto three others simultaneously (at a rate of up to 72 MBps), the duplicator/docking station can save you time and effort. As an external HDD dock, it can be connected to your host computer through USB 3.0 or eSATA, providing data transfer speeds up to 5 Gbps or 3Gbps respectively, from the hard drives to your computer system.
Features Quick and Secure Erase functions and support for IDE hard drives using the included SATA to IDE hard drive adapter (SAT2IDEADP).
  • Efficient drive management
    The dock accommodates up to four drives at once, allowing for easy management and duplication tasks, reducing the time and effort needed for data operations.
  • High-speed data transfer
    Featuring USB 3.0 and eSATA interfaces, the dock provides fast data transfer rates of up to 300 MBps, ensuring efficient handling of large files.
  • Robust compatibility
    This duplicator dock is tested to work seamlessly with both SATA and IDE drives, making it a versatile choice for various storage solutions.
  • Reliable performance
    The device has been tested with high-capacity drives, supporting up to 4 TB for 3.5" and 1 TB for 2.5" drives, ensuring dependable operation in various scenarios.
  • User-friendly setup
    With its standalone functionality, this dock simplifies the duplication process, allowing users to operate it without needing a separate computer.
StarTech.com 4 Bay USB 3.0/ eSATA Hard Drive Duplicator Dock for 2.5" & 3.5" SATA/ IDE SSD HDD - Standalone 1:3 Copier Docking Station (SATDOCK4U3RE) - hard drive duplicator
Hard drive duplicator
0 (installed) / 4 (max)
Supported Drives
SATA-300
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
No HDD
Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
AC 120/230 V - 50/60 Hz
29 cm x 17 cm x 8.3 cm
1.11 kg
1-year warranty
P/N: SVA12DN4NEUA
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
4
Supported Drives
SATA-300
Storage Controller
SATA - integrated (SuperSpeed USB 3.0 / eSATA-300)
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Max Storage Devices Qty
4
Hard Drive
No HDD
Expansion Bays
4 (total) / 4 (free) x external - 2.5" / 3.5" shared
1 x USB 3.0 - 9 pin USB Type B , 1 x eSATA 3Gb/s - 7 pin external Serial ATA , 4 x SATA 3Gb/s - 22 pin Serial ATA
Tested with up to 4TB 5400 RPM 3.5” hard drives, tested with up to 1TB 5400 RPM 2.5” hard drives
FCC, RoHS
External power adapter
29 cm
17 cm
8.3 cm
1.11 kg
Limited warranty - 1 year
5 °C
80 °C
8 - 90%
P/N: SVA12DN4NEUA
7P25 StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £9.74
7P25 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.30
7P25 StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.99
7P25 StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock In Stock £409.75
7P25 StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.52
7P25 StarTech.com Standalone 1:5 USB Flash Drive Duplicator and Eraser In Stock £441.84
7P25 StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock – Hard Drive Cloner 6Gbps In Stock £70.73
7P25 StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/ Multi HDD SSD Image Backup Library In Stock £268.30
7P25 StarTech.com USB 3.0 Standalone Eraser Dock In Stock £209.69
7P25 StarTech.com Hard Disk Drive Duplicator Dock In Stock £80.83
7P25 StarTech.com SATA/SAS Duplicator & Eraser In Stock £1,026.33
7P25 StarTech.com USB and SATA Cloner / Eraser In Stock £485.61
7P25 StarTech.com SATA SSD/HDD Eraser/Dock - 4Kn In Stock £234.88
7P25 StarTech.com StarTech.com Hard Drive Eraser In Stock £499.61
7P25 StarTech.com USB Duplicator and Eraser 1:15 In Stock £1,045.73
7P25 StarTech.com USB Duplicator and Eraser 1:7 In Stock £661.43
7P25 StarTech.com M.2 SATA & M.2 NVMe Duplicator In Stock £691.38
Type: Hard drive Duplicator
HD Size: 2.5 / 3.5 shared
Power Supply: Power adapter
