Duplicate one SATA Hard Drive onto three Hard Drives simultaneously.
The SATDOCK4U3RE USB 3.0 and eSATA 1-to-3 Hard Drive Duplicator docking station enables you to duplicate/clone a single SATA hard drive to up to three other SATA drives simultaneously, as a standalone device. The duplicator can also function as a regular 4-bay hard drive docking station, by connecting to a host computer system. Large capacity drives (tested with up to 4TB 3.5" and 1TB 2.5" drives per bay) can be used to greatly enhance your computer's storage/backup capabilities.
Able to perform 1:3 sector duplication, including HPA, from a single SATA drive onto three others simultaneously (at a rate of up to 72 MBps), the duplicator/docking station can save you time and effort. As an external HDD dock, it can be connected to your host computer through USB 3.0 or eSATA, providing data transfer speeds up to 5 Gbps or 3Gbps respectively, from the hard drives to your computer system.
Features Quick and Secure Erase functions and support for IDE hard drives using the included SATA to IDE hard drive adapter (SAT2IDEADP).
- StarTech.com 4 Bay USB 3.0/ eSATA Hard Drive Duplicator Dock for 2.5" & 3.5" SATA/ IDE SSD HDD - Standalone 1:3 Copier Docking Station (SATDOCK4U3RE) - hard drive duplicator
- Hard drive duplicator
- Black
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- Supported Drives
- SATA-300
- Storage Controller
- SATA (SATA 3Gb/s)
- Hard Drive
- No HDD
- OS Required
- Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
- Power
- AC 120/230 V - 50/60 Hz
- 29 cm x 17 cm x 8.3 cm
- 1.11 kg
- 1-year warranty
- Designed For
- P/N: SVA12DN4NEUA
- Enclosure Colour
- Black
Chassis
- 0
- Supported Devices / Modules Qty
- 4
- Supported Drives
- SATA-300
Storage Controller
- SATA - integrated (SuperSpeed USB 3.0 / eSATA-300)
- Interface Type
- SATA 3Gb/s
- Data Transfer Rate
- 300 MBps
- Max Storage Devices Qty
- 4
Hard Drive
- No HDD
- Expansion Bays
- 4 (total) / 4 (free) x external - 2.5" / 3.5" shared
- 1 x USB 3.0 - 9 pin USB Type B , 1 x eSATA 3Gb/s - 7 pin external Serial ATA , 4 x SATA 3Gb/s - 22 pin Serial ATA
- OS Required
- Tested with up to 4TB 5400 RPM 3.5” hard drives, tested with up to 1TB 5400 RPM 2.5” hard drives
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- 29 cm
- 17 cm
- 8.3 cm
- 1.11 kg
- Limited warranty - 1 year
- 5 °C
- 80 °C
- 8 - 90%
- Designed For
- P/N: SVA12DN4NEUA
StarTech.com 6 ft Shielded External eSATA Cable M/M | In Stock | £9.74 |
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.30 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £19.99 |
StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock | In Stock | £409.75 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.56 |
StarTech.com Standalone 1:5 USB Flash Drive Duplicator and Eraser | In Stock | £441.84 |
StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock – Hard Drive Cloner 6Gbps | In Stock | £84.05 |
StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/ Multi HDD SSD Image Backup Library | In Stock | £268.30 |
StarTech.com USB 3.0 Standalone Eraser Dock | In Stock | £209.69 |
StarTech.com Hard Disk Drive Duplicator Dock | In Stock | £80.83 |
StarTech.com SATA/SAS Duplicator & Eraser | In Stock | £1,045.83 |
StarTech.com USB and SATA Cloner / Eraser | In Stock | £485.61 |
StarTech.com SATA SSD/HDD Eraser/Dock - 4Kn | In Stock | £234.88 |
StarTech.com StarTech.com Hard Drive Eraser | In Stock | £499.61 |
StarTech.com USB Duplicator and Eraser 1:15 | In Stock | £1,045.73 |
StarTech.com USB Duplicator and Eraser 1:7 | In Stock | £661.43 |
StarTech.com M.2 SATA & M.2 NVMe Duplicator | In Stock | £691.38 |
