StarTech.com 4 Bay External Hard Drive Array Storage Tower – eSATA USB 2.0 Enclosure
Quicklinx: 6LBNWS00 Mfr#: SAT3540U2E
Turn four SATA drives into an external storage device with USB 2.0 and eSATA connectivity. StarTech.com's SAT3540U2E Multi Bay External Hard Drive Enclosure is a high-performance 4-drive SATA enclosure connected to host systems through eSATA and/or USB. The enclosure can be connected to two systems simultaneously, one through USB and one through eSATA, allowing users to share installed SATA hard drives between the computers by switching host connections back and forth at the touch of a button.
The 4-drive SATA enclosure works with high capacity (tested with up to 4TB per bay) 3.5in Serial ATA hard drives (SATA, SATA II, SATA III) and features a removable front cover that ensures easy access while installing or removing the drives.
StarTech.com 4 Bay Hard Drive Array Storage Tower - eSATA USB 2.0 Enclosure - hard drive array
Hard drive array
Max Supported Capacity
16 TB
USB 2.0, SATA 3Gb/s
4 (max)
Supported Drives
SATA-300
Built-in Devices
Led panel
Storage Controller
RAID (SATA 3Gb/s) - RAID JBOD
Hard Drive
0 HDD SATA 3Gb/s - hot-swap
Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
AC 120/230 V
12.6 cm x 21.5 cm x 17 cm
1.8 kg
1-year warranty
Hard drive array
Enclosure Colour
Chassis
Built-in Devices
Led panel
Supported Devices / Modules Qty
4
Supported Drives
SATA-300
Storage
16 TB
HDD Array External Interface
USB 2.0, SATA 3Gb/s
Storage Controller
RAID
Channel Qty
4
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive, disk array (RAID)
RAID Level
JBOD
Hard Drive
HDD - hot-swap
0
Interface Type
SATA 3Gb/s
Expansion Bays
4 (total) / 4 (free) x hot-swap - 3.5"
1 x eSATA 3Gb/s - 7 pin external Serial ATA , 1 x USB 2.0 - 4 pin USB Type B
1 x eSATA cable , 1 x USB cable
FCC, RoHS
External power adapter
AC 120/230 V
12.6 cm
21.5 cm
17 cm
1.8 kg
Limited warranty - 1 year
-20 °C
60 °C
