StarTech.com 4-Bay Backplane for SSD/HDD
Quicklinx: BFP4WS00 Mfr#: SATSASBP425
£76.61 ex VAT
£91.93 inc VAT
Hot swap with ease by installing four SSDs/HDDs into one 5.25in bay. Now it's easy to drive share and enhance the storage capabilities of your server or PC. This mobile rack backplane lets you install four 2.5in SATA or SAS solid-state or hard disk drives into a single 5.25in bay and quickly hot swap them between systems. It's ideal for systems integrators and administrators who are looking for flexible management of their data storage.
The mobile rack backplane is engineered to protect your valuable data and provide reliable performance. The aluminum housing is designed for enhanced heat dissipation, while two 40mm fans improve air flow to minimize heat build-up and ensure optimum operating temperature.
You can lock the removable steel trays in place, providing an enhanced level of drive protection. The backplane can be mounted either vertically or horizontally, for error-free tray insertion and maximum compatibility with servers or desktop computers. The Non-Scratch SATA (NSS) connector provides a high 50,000+ insertion rating, your assurance of long-lasting performance of both the drives and the bay.
Many fast-paced work environments require drives to be removed regularly. Hot swap between systems quickly, without shutting down, with the convenient backplane. The included trays are interchangeable, working with both the 4-bay backplane and the single-bay backplane (SATSASBP125) so you can hot swap between systems for easy file access.
Designed for versatile use, the backplane supports an extensive range of both SATA or SAS based HDDs and SSDs, from 5 to 15mm in height.
To maximize the performance of your drives, the mobile rack supports SAS II and SATA III performance for transfer speeds up to 6 Gbps when paired with a compatible controller. The backplane also works with your preferred RAID controller or Hyper Duo controller to produce a high-performance or redundant storage solution.
StarTech.com 4-Bay Mobile Rack Backplane for 2.5in SATA/SAS Drives - Hot Swap SSDs/HDDs from 5-15mm - Supports SAS II & SATA III (6 Gbps) - storage enclosure
Storage enclosure
4 (max)
Supported Drives
SATA-600 / SAS-2
Hard Drive
0 SATA 6Gb/s / SAS 6Gb/s - hot-swap
14.6 cm x 15.15 cm x 4.2 cm
740 g
P/N: SATBP125VP, SATSASBP125
Storage enclosure
Enclosure Colour
Chassis
Supported Devices / Modules Qty
4
Supported Drives
SATA-600 / SAS-2
CPU
No CPU
Hard Drive
Hot-swap
0
Interface Type
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5"
4 x SATA 6Gb/s - 7 pin Serial ATA , 4 x SAS 6Gb/s - 7 pin Serial ATA , 1 x - 4 PIN internal power
Key lock, LED indicator, built-in cooling fan
4 x Serial ATA cable - 4 m
MTBF
30,000 hours
FCC, RoHS
4 x drive trays, 20 x drive mounting screws, 8 x backplane mounting screws
14.6 cm
15.15 cm
4.2 cm
740 g
55 °C
5 - 65%
BFP4 StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F In Stock £2.99
BFP4 StarTech.com 12in Latching SATA Cable In Stock £3.65
BFP4 StarTech.com 18in Latching SATA Cable In Stock £4.20
BFP4 StarTech.com 24in Latching SATA Cable In Stock £5.66
BFP4 StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power In Stock £5.34
BFP4 StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane In Stock £41.21
BFP4 StarTech.com 2.5in SATA Removable Hard Drive Bay for PC Expansion Slot In Stock £24.97
BFP4 StarTech.com SATA to LP4 Power Cable Adapter with 2 Additional LP4 In Stock £5.08
BFP4 StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £7.06
BFP4 StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £4.76
BFP4 StarTech.com 6in Latching SATA Cable In Stock £3.68
BFP4 StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £3.79
BFP4 StarTech.com 4x SATA Power Splitter Adapter Cable In Stock £5.88
BFP4 StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F In Stock £5.50
BFP4 StarTech.com 12in SATA to Molex LP4 Power Cable Adapter - F/M In Stock £4.00
BFP4 StarTech.com Mobile Rack Backplane In Stock £26.53
BFP4 StarTech.com 4-Bay Backplane for SSD/HDD In Stock £76.61
BFP4 StarTech.com 2.5" Hot Swap Hard Drive Tray In Stock £9.34
BFP4 StarTech.com 6" SATA Power Y Splitter Cable In Stock £7.06
Stock Status: In stock
