Connect and hot swap four 3.5in SATA III or SAS II hard drives to your computer system in three 5.25" bays, with support for transfer speeds up to 6 Gbps. The HSB4SATSASBA Removable 4-drive Backplane makes inserting and removing drives fast and easy, by turning three 5.25" bays into a hot-swappable interface for up to four 3.5" SATA or SAS hard drives (HDD).
For added versatility, the hot swap bay can interface with SATA I/II/III and SAS I/II hard drives - an ideal solution for enterprise system applications.
For a quick and secure method of installing and removing drives, the backplane features ejection levers and a key-lock design. To help prevent drive failure, the bay provides drive cooling with a built-in fan and excellent heat dissipation with a vented aluminum enclosure.
- StarTech.com 4-Bay Mobile Rack Backplane - Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III - 6 Gbps HDD (HSB4SATSASBA) - storage mobile rack
- Storage mobile rack
- Black
- Expansion Bays
- 4 x hot-swap - 3.5"
- Compatible Bay
- 3 5.25"
- Hard Drive Form Factor Compatibility
- 2.5"
- Supported Interface
- SATA-600
- Drive Connector
- 29 pin internal SAS (SFF-8482)
- Data indicator, power indicator, cooling fan
- Product Material
- Aluminium
- 14.5 cm x 19.8 cm x 12.5 cm
- 120 g
- 2-year warranty
- 2.5"
- Product Material
- Aluminium
- Black
- SATA-600
Storage Controller
- Processor
- No CPU
- Bays
- 4 x SATA 6Gb/s - 29 pin internal SAS (SFF-8482)
- Connections
- 4 - 7 pin Serial ATA , 2 - 15 pin Serial ATA power
- Compatible Bay
- 3 x external 5.25"
- Included Accessories
- 2 security keys, 8 x screws
- Cables Included
- 4 x Serial ATA cable
- FCC, RoHS
- Limited warranty - 2 years
- 14.5 cm
- 19.8 cm
- 12.5 cm
- 120 g
- 0 °C
- 55 °C
- 5 - 85%
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.60 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.26 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.48 |
StarTech.com 18in Latching SATA Cable | In Stock | £3.94 |
StarTech.com 24in Latching SATA Cable | In Stock | £6.08 |
StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive | In Stock | £17.65 |
StarTech.com 6in 4 Pin Molex to Right Angle SATA Power Cable Adapter | In Stock | £5.00 |
StarTech.com 8in Latching SATA to SATA Cable - F/F | In Stock | £5.30 |
StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA | In Stock | £4.22 |
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F | In Stock | £5.30 |
StarTech.com 4 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III | In Stock | £85.59 |
StarTech.com 18in Right Angle SATA Cable | In Stock | £4.36 |
