StarTech.com 4.5m C14 to C13 Power Extension Cord
Quicklinx: J4LRWS00 Mfr#: PXTC13C141415FEU
£13.58 ex VAT
£16.29 inc VAT
This certified C14 to C13 power extension cord extends connections from a PDU or UPS to servers, monitors, printers, and other IT equipment. The 15ft (4.5m) length provides extra reach, enabling flexible hardware placement in server rooms, network closets, and workstations. Designed for Safety Engineered to meet strict European safety regulations, this power cord is KEMA-KEUR certified and built to H05VV-F classification for EU power standard compliance. The VW-1 flame rating enhances fire safety, and is suitable for environments where fire resistance must be considered. Extended Reach The 15ft length facilitates added distance between devices and power sources, allowing easier positioning of equipment without being limited by outlet locations. Durable Construction Built for longevity, this C14 to C13 power extension cord features a fully molded design and is made from 100% copper wire. It is rated for 250V at 15A with 14AWG conductors, ensuring reliable and stable power transmission.
  • Designed for Safety
  • Extended Reach
  • Durable Construction
StarTech.com 4.5m Power Extension Cord, C14 to C13, 15A 250V, KEMA-KEUR - power extension cable - IEC 60320 C14 to power IEC 60320 C13 - 4.6 m
Power extension cable
Molded, copper conductors, Service Junior Thermoplastic (SJT) jacket
Length
4.6 m
Connector
Power IEC 60320 C14
Connector (Second End)
Power IEC 60320 C13
Rated Voltage
AC 250 V
Rated Current
15 A
Jacket Material
PVC
American Wire Gauge (AWG)
14
Rated Voltage
AC 250 V
Rated Current
15 A
Length
4.6 m
Outside Diameter
9.2 mm
380 g
Connector
Power IEC 60320 C14
Power IEC 60320 C13
H05 VV-F, KEMA-KEUR, RoHS
Shipping Width
29 cm
Shipping Depth
14.5 cm
Shipping Height
5 cm
Shipping Weight
380 g
