This certified C14 to C13 power extension cord extends connections from a PDU or UPS to servers, monitors, printers, and other IT equipment. The 15ft (4.5m) length provides extra reach, enabling flexible hardware placement in server rooms, network closets, and workstations. Designed for Safety Engineered to meet strict European safety regulations, this power cord is KEMA-KEUR certified and built to H05VV-F classification for EU power standard compliance. The VW-1 flame rating enhances fire safety, and is suitable for environments where fire resistance must be considered. Extended Reach The 15ft length facilitates added distance between devices and power sources, allowing easier positioning of equipment without being limited by outlet locations. Durable Construction Built for longevity, this C14 to C13 power extension cord features a fully molded design and is made from 100% copper wire. It is rated for 250V at 15A with 14AWG conductors, ensuring reliable and stable power transmission.
Designed for Safety
Engineered to meet strict European safety regulations, this power cord is KEMA-KEUR certified and built to H05VV-F classification for EU power standard compliance. The VW-1 flame rating enhances fire safety, and is suitable for environments where fire resistance must be considered. -
Extended Reach
The 15ft length facilitates added distance between devices and power sources, allowing easier positioning of equipment without being limited by outlet locations. -
- StarTech.com 4.5m Power Extension Cord, C14 to C13, 15A 250V, KEMA-KEUR - power extension cable - IEC 60320 C14 to power IEC 60320 C13 - 4.6 m
- Power extension cable
- Molded, copper conductors, Service Junior Thermoplastic (SJT) jacket
- Length
- 4.6 m
- Connector
- Power IEC 60320 C14
- Connector (Second End)
- Power IEC 60320 C13
- Rated Voltage
- AC 250 V
- Rated Current
- 15 A
- Black
- Limited lifetime warranty
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 14
- Rated Voltage
- AC 250 V
- Rated Current
- 15 A
- Length
- 4.6 m
- Outside Diameter
- 9.2 mm
- Black
- 380 g
- Connector
- H05 VV-F, KEMA-KEUR, RoHS
- Shipping Width
- 29 cm
- Shipping Depth
- 14.5 cm
- Shipping Height
- 5 cm
- Shipping Weight
- 380 g
